Page 24 of 26 FirstFirst ... 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 231 to 240 of 253
Thread: Wheel fitment thread- post your will this fit questions in here
  1. #231
    May 2011
    steve
    Thanks Geoff. I want the wheels to fill up the guards with the wheels tucked under the guards - probably a lightly negative offset as well.
    The image below is exactly the look I'm after, would anyone know what sort of wheels specs these are by eye?
    Edit**
    So I just found the source of this image online and it looks like the specs are:
    Font wheels 15×9″ -15.
    Rear wheels 15×10″ -25
    Would the following specs a) look similar to this (ie look good) and b) fit with unmodified guards that are only rolled?
    Font wheels 15×8″ 0.
    Rear wheels 15×8.5″ -5
    Thanks again for any help.
  2. #232
    Veteran johl's Avatar
    Johl
    You won't go wrong with those sizes mate
  3. #233
    Aug 2010
    Geoff
    mt dandenong
    From my experience you'd need a stretched tyre on the rear with a guard roll and fronts would need a roll aswell.
    The rear wheel bead will be dead on the stock wheel arch, as will the front depending on camber setting
  4. #234
    Jul 2009
    shaun
    nsw
    port macquarie
    I'm pretty excited I've just ordered 15x8 -6 front and 15x8 -18 for the rear on stock trueno coupe gards I think I might need a good stretch to fit I was hoping to go 195 50 but may have to go 185 50 what are your thoughts. Also rolled guards pretty hard and I'm not slamming the car top of tyre will be just tucking thanks guys
  5. #235
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    15x8 -18 will poke about 15mm each side. 195/50 will be pushing it depending on how stiff your springs are.
  6. #236
    Senior Member Tally's Avatar
    Tally
    Looking at getting some 15s for my AE86. Wanting to know whats the biggest tire and/or rim width I can fit under stock rear guards with rolled lips. Id imagine low + offset on a 7/7.5/8???
    Was looking at 225/55/15 tires,
    ALWAYS LOOKING FOR KE25 COROLLA PARTS
  7. #237
    Aug 2010
    Geoff
    mt dandenong
    8" zero offset is as far as sensible goes in my opinion. You can go wider with a positive offset (keeping in line with guard) ie. 9" +25 will still fit like a 8" zero
    James' panda coupe has 205/50/15 on 15" zero rims. Inner lip rolled, sits nice
  8. #238
    Tally
    ^ awesome help dovey - gives me something to work with when looking for wheels ")
    I was thinking of going ~ +20/25 or so to get the track in as much as possible but with the widest width as im drag racing
    but then again is rim width that important if I can still fit a 225 on a 7" rim? smaller rim = less weight and more sidewall flex????
  9. #239
    Aug 2010
    Geoff
    mt dandenong
    Should be fine for a street drag car. Get a 185 for the fronts for less rolling resistance though.
  10. #240
    Veteran Konakid's Avatar
    Henry
    Eastern
    For drag you want a bit of sidewall, id go 15x7 0 to +10 with a 225/50
  1. The Wheel Fitment Thread
    By Konakid in forum Technical - Rims & Tyres
    Last Post: 8th March 2016, 07:43 AM
  2. Wheel clearout - 13",14",15",18"
