Results 1 to 10 of 20
Thread: W5x in AE86 - which back housing?
    Senior Member PuGZoR's Avatar
    Andy
    Thornlands
    Default W5x in AE86 - which back housing?
    Ello boys and girls, first post since the forum shift...
    I've got a W58 in my AE86 behind a Niteparts Bellhousing and 4A, obviously. Now, my gearstick comes up just a little too far back than I'd like, and a very good friend of mine tells me that there's a fabled other W5x out there with a different gear stick location, that should be interchangable.
    So my question is... what's this bitch off, so I can find one?
    Senior Member koulouris#03's Avatar
    Nsw
    EarlwoodNsw
    Au
    how do you get these nite parts bellhousings???
    sorry to get in your thread but im trying a w conversion to my 86 and can not work out how to get in contact with these guys....
    i think what your after is just a shifter locator or something. im not sure though.
    cheers.
    john.
    kiss ass like a bitch, so you can get ritch... but your boss gets ritcher of you!!!!
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    grinder+welder or sa63 shifter
    Veteran biggo's Avatar
    Nick
    Noosa
    Or ra60/65 fits
    You need one with the shifter in the middle of the thingy. Theres Front/Mid/Rear/Remote shfter locations in the w5x range.
    Do nightparts bells come with spigot bearing spacers?
    Dan/Rio
    Randwick
    i was under the impression that the sa63 shifter puts the sifter in the right position for an ae86
    Andy
    Thornlands
    So this fabled SA63 w5x "gear housing top thingy that holds the shifter" is the go?
    Niteparts is NZ based. Forget how I got my bellhousing, lol, think I had an email address for Brendan ages ago. Actually, come to think of it, think I got mine through a group buy on toymods.
    As for this spigot bearing spacer you speak of biggo? Well, I have no idea what you're talking about.
    Veteran slydar's Avatar
    Dimitri
    ive heard castlemaine rod shop will do you an exchange for $50 or $100. i have the sa63 one. which one is yours in the pic in that link? might end up needing to change it so its possible we could swap if your set up suits what im doing.
    Andy
    Thornlands
    Mine looks like the furthest back one, more than anything else. The guy I got it off (from Supraforums.com.au) said it was from a JZA80 non-turbo, and it definitely seemed clean enough (without looking like it'd been cleaned) to fit that too...
    *shrugs*
    Castlemain Rod Shop have a heap of accessories for them too. Look:
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    cut shifter hole.... problem solved
    come to think of it i did the w58 conversion in my car a while ago behine my old 20v, i didnt even need to cut the hole... the shifter was really close to the back left of the hole but didnt hit, you should be fine but...
    w series boxes come with 4 different shifter positions
    front/middle/rear/ hanging over the rear
    mine was the one just at the rear, unless you have the furthest back one you should be fineand even then u wont need to cut the hole much
    MY JZX83 (clicky)
    Dimitri
    the jza80 box has a remote shifter. the set up isnt pictured in that link. its quite a rare part.. dunno how usefull it is though. will be too far back for me. i thought you had an ma61 w box, cos i remember you wrecking one. i am guessing if anything i might need to come forward a touch too. so cant help.
  1. W5X series Gear boxs in an ae86. Costly?
    By The Enthusiast in forum Technical - Questions
    Last Post: 5th April 2016, 01:07 PM
  2. WTB W5x to 4AGE complete conversion + disk lsd diff to suit ae86
    By burcoty in forum Cars or Parts Wanted
    Last Post: 13th November 2012, 07:08 PM
  3. Replies: 9
    Last Post: 25th February 2012, 06:08 PM
  4. NSW: AE86, Fresh 4AGE, W5x, LSD
    By Andyy in forum Cars for Sale (Toyota Only)
    Last Post: 19th May 2011, 10:03 PM
  5. Vic: back half of the water pump (thermo housing bolts to it)
    By BlueLevin in forum Cars or Parts Wanted
    Last Post: 26th October 2010, 11:10 AM
