Results 1 to 9 of 9
Thread: AE86 Tacho modifications
    Veteran Andy San's Avatar
    Andy
    Adelaide Hills
    Default AE86 Tacho modifications
    Does anyone have the link to the page which explained how to modify your circuit board in the tacho so it works with a microtech/haltech tacho signal wire?
    I used to have the page saved, but it seems to have gone missing.
    had all the step by step pictures and the explanation of all the parts required.
    Andy
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    i would also like to find this
    might have a dig on google
    MY JZX83 (clicky)
    Brendan
    NORTHSIDE YO
    2 mins and found
    link to ae86dc tech article
    http://www.ae86drivingclub.com.au/fo...4805#post34805
    MY JZX83 (clicky)
    Andy
    Adelaide Hills
    cool thanks for that, my googleing found it as well. Tacho works now, yay!
    Andy
    Senior Member Medwin_3sGTE_AE86's Avatar
    Bendyaumum
    Southern
    john
    nsw
    liverpool
    hi guys ,
    on my tacho everything works as normal without this mod. and i am running a mirco tech ...
    will doing this mod give me a more accruate readout of speed and revs?
    Bendyaumum
    Southern
    Quote Originally Posted by redsprinter View Post
    hi guys ,
    Hey mate
    You must be running a distributor with a single coil setup, Yes?
    This is more aimed at cars running direct fire setups, ie 4x coils instead of 1.
    john
    nsw
    liverpool
    sorry for being brief.. my car is running a 4agze, that has been turbo'ed . using the
    4agze DLI and cas.
    im using a mirco tech lt10s. im interested in this mod if it will give me a more accruate reading as im running a w58 gearbox + 4.1 final ratio and 195/50/r15s . im pretty sure my tacho is out of wack .
    Bendyaumum
    Southern
    Depending on how you've wired the tacho up, will affect its reading.
    I think you mean you think your SPEEDO is out..... Which the tacho has nothing to do with....
  1. 4kc Modifications
    By AE86R in forum Technical - Questions
    Last Post: 11th March 2009, 06:40 AM
  2. Modifications/Engeneering
    By ADICTD2BASS in forum Technical - Questions
    Last Post: 7th January 2008, 05:28 PM
