Results 1 to 9 of 9
Thread: Help with EFI
    Jacks
    nsw
    sydney
    Default Help with EFI
    Ok so I want to convert my sprinter from twin webers to efi, just to make sure I havent forgotten anything which specific parts do I need for the conversion? Ecu, Injectors etc..
    Senior Member adam's Avatar
    Adam
    When going from a 4k to 4age, I needed
    - Lifter pump
    - High pressure pump
    - Thicker fuel lines
    - Fuel rail with fuel pressure regulator
    - Injectors
    - Wiring
    - ECU
    - Fuel filter
    I think that's it on the fuel side of things.
    Vancouver, BC
    Downtown
    Canada
    make sure you've got all the required sensors and loom plugs - tps should come with throttle body, intake air temp sensor, cold start injector & switch (if you choose to run it).
    Moderator Sam-Q's Avatar
    Endeavour Hills
    with the fuel lines they need to be changed to be an efi specific type, thats for the rubber ones as the steel lines on the body are fine. Also use a fuel clamp specificly for efi
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    You don't necessarily need to convert the hard lines to a larger size, if you run a surge tank in the engine bay and run a low pressure pump to fill the surge tank it will work fine. It just not a good idea to put an EFI pump at the tank end and have it pushing through carbie fuel lines.
    Jacks
    nsw
    sydney
    Hmm.. I see, so say If I were to get an 4age 20valve blacktop engine (including the manifolds) to replace my current engine then I still should be able to run the standard ECU from that engine right? What else should I need/replace if I were to do as such? My flywheel, gearbox and clutch shouldn't be an issue..
    Lawrence
    Wollongong
    You're going to have the dizzy headache.... unless you relocate the dizzy or find a DLI conversion you'll have to run an aftermarket computer.
    Jacks
    nsw
    sydney
    Ahh I see.. So I guess I'll need an aftermarket computer, other then that what else would I need to replace for my car to be kept up with the engine swap? Just want to see some of my options before I change anything to my car.. I'm not sure if I should convert my engine to EFI or replace the whole engine in total.. What do you guys think? My engine atm is a 1.8 Litre bottom end 7A Block with a 4AGE Head running on twin webers.
    Lawrence
    Wollongong
    Is think you're best off selling the entire engine as a package and start a fresh with an EFI motor. You'll probably break even assuming you do the work yourself.
  1. carb(??) Vs EFI
    By dave2221 in forum Toyotas in the Media
    Last Post: 13th July 2006, 07:03 PM
  2. help - efi tank conversion...
    By sprintrphile in forum Technical - Questions
    Last Post: 15th May 2006, 08:49 PM
  3. efi wiring question
    By streets in forum Technical - Questions
    Last Post: 25th April 2006, 01:39 AM
  4. efi 4ac
    By rolla_boy70 in forum Technical - Questions
    Last Post: 6th December 2005, 10:28 PM
