what is SR's weakpoint?
Nope.. Just ca's and rb's they have silmiar head and gallery design and have same problems.. Sr's are completely diffrent
full time mechanic... part time toyota tech lol
Probably just there rocker setup.. They are quiet a good engine... But i couldnt be assed changing loom.. Buying sr .. Rebuilding it... Retuning ecu all just to go sr
Motor is waiting for crane on weekend then ill strip it sunday and to machine shop it goes..
I've thought this and made the same mistake before.......If your gunna do something man,you may as well do it right the first time.........but on the same note,this is an S13......just buy an SR20det one an save some time,true!
lol
nice car anyway man,good luck with it which ever way it goes!
43ger
Performance
SINCE 2008
Thanks dude.. Yer if i wanted sr i would buy one put my coilover in it and swap my ps1000 into it and done... For now sense im a mechanic and it wont cost me much ill do a rebuild on the ca with some nice bits and run it.. Going to address oiling issue while i do rebuild to so should be quiet reilable.. And it made good power before with a bung bottom end so it will do me once rebuilt..
Engine out!! Soon to be stripped.. Found turbo has too much play so going something else..
Engine is stripped and at machine shop.. Getting JE pistons. Arp head studs... Acl race series bearings.. metal head gasket set.. And new turbo .. Cant wait to build it ...
Also can anyone who has built a ca tell me if modifying the plate in the crank case that is below the breather will sort the oil issues
Update.. Engine a machinist getting block and head done.. Getting JE pistons.. Arp head studs.. Full race metal vrs gasket set... And acl race series bearings and in next week or so should be sourcing a gt28bb for it as my t25 is near death..
