Results 1 to 10 of 60
Thread: AE86 proportional valves (brakes n shizno)
    Elite rthy's Avatar
    Leo
    Tulla
    Default AE86 proportional valves (for drum to disk rear end)
    For the vehicles we are interested in, the proportioning valve turning point is set at:
    AE86, ADM = 15kg/cm^2
    AE86, JDM GT with drums, Euro GT with disk = 20kg/cm^2
    AE86 with disk rear, AE85, some Euro = 30kg/cm^2
    It is worth noting that these same valves come on a host of Toyota vehicles, including the 1977 Mini made in Australia. Also, the AE85 (with drums) uses the exact same p-valve as the GTV and GT-Apex models with disks.
    Update: All of my assumption are incorrect. See Jonny's post on the 2nd page
    Due to the lack of proportional valve stock at toyota... whats the difference between the rear drums and disk proportional valves?
    besides the drums has a single piece proportional valve and disk two piece?
    is there a way to modify the drum propvavle to work with disks the same way as the disk propvavle?
    the reason why i ask is that the drum wheel cylinders require more liquid for the shoes to hit the drums... so when swaping over to a disk rear end the rear brakes force will be stronger than the front.
    i did look around on the internets but didnt find anything solid with modding to the drum pv to use on disks rear ends.
    edit: this is for drum to disk rear end, factory swap over
    Using the Factory ADM PV can you modify it to use disk rear end?
    not after adjustable/aftermarket pv as i would have got one along time ago.
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    removing the spraings theory-
    it makes it easier to open the valves which makes the front brakes work earlier.
    i havent tested it personally
    West
    Just get the same proportioning valve as the diff came with. Failing that you could always use something like this in the rear line to the diff, after the factory proportioning valve:
    If all you need is to limit the flow, thats all you need.
    Senior Member n00bvak's Avatar
    Novak
    SOR
    ^^^ I have a willwood adjustable proportioning valve setup for my hydraulic handbrake, really easy to setup and way lighter than the stock one.
    And by far the best thing is you can setup whatever brake bias you want!!!
    Check my build tread link below for instal pics (its on the side of the hydraulic handbrake)
    --- All your base are belong to Phil Bradshaw!!! ---
    <<< blog >>> build thread<<<
    Elite rthy's Avatar
    Leo
    Tulla
    yea hard finding a factory disk pv, bought a rear pv from toyota but they no longer have stock for the front pv! so might have to buy second hand or other way.
    not looking at getting a flow limiter at this stage
    edit:
    also which spring is removed?
    Reeece
    Casula
    ive got r32 bmc , hilux front brakes and r31 rear disc brakes.. I am just running the stock pv seems to be sweet ??
    Elite rthy's Avatar
    Leo
    Tulla
    thats cos u got the bigger mc, im still using the factory MC, factory jdm front brakes, factory jdm disk rear end and factory adm drum PV. so once the brakes heat up the rears lock up pretty easy which only happend at winton.
    if i get paid tommorow ill buy some brake fuild and try removing that spring and see wat happens.
    Reeece
    Casula
    i see upgrade to r32 ?
    Elite rthy's Avatar
    Leo
    Tulla
    with the stock brake? nahh
    altho i do plan on using a r32 bmc on my ae71 with rx7 brakes n stuff
    Mt Macedon
    Try just pulling the spring out of your current valve. The bit that deals with the rear lines, open it up, remove spring and put it back together. I did that years ago and seems to work.
    At least give it a try before chasing expensive parts around the country.
  1. Blocked brake proportional valve
    By BARWICK in forum Technical - Questions
    Last Post: 25th October 2011, 06:53 PM
  2. Telling the difference between ADM and JDM proportional valves
    By jamekins in forum Technical - Questions
    Last Post: 1st May 2010, 01:29 AM
  3. [vic]JDM proportional valve
    By rthy in forum Cars or Parts Wanted
    Last Post: 23rd February 2009, 08:00 PM
  4. WTB JDM Brake Proportional valves
    Last Post: 28th July 2008, 05:07 PM
  5. Jap AE86 Brake Proportional Valve
    By Mr Fujiwara in forum Technical - Questions
    Last Post: 28th February 2006, 02:49 PM
