Results 1 to 10 of 89
Thread: TE72 Rolling on Hoshinos
    Senior Member stouty's Avatar
    Leigh
    Forster
    Default TE72 Rolling on Hoshinos
    * Engine
    2TG early model with dual side draft 40mm solex carbs
    58.5kw 224nm at 5500rpm
    3 core radiator
    12' thermo fan
    2lt Orchy bottle catch can
    * Exhaust
    4 into 1 tunned length OBX stainless steel extractors
    2.25" exhaust with sports stainless steel muffler and twin pipes out the back
    * Front Suspension
    Cut king springs
    kyb excel g shocks
    Cusco 30mm RCA's
    xt130 Control Arms
    21mm swaybar
    Cusco Camber Tops
    Cusco Strut Brace
    New tie rod end ball joints
    New wheel bearings
    Full nolathane replacement bushes
    -2.2 Negative camber
    maxed out castor arms
    0.7mm toe out
    *Rear Suspension
    Cut king springs
    TRD 8 way adjustable green shocks
    Cusco strut brace
    Strut brace for harness
    AJPS traction brackets
    New rubbers on 4 link
    Running no sway bar
    * Driveline
    T-50 gearbox
    TRD LSD
    TRD 4.3
    One piece tailshaft
    * Interior
    No back seats
    Sound deadening removed
    Repainted white
    Nardi wheel with quick release boss kit
    Sparco Sprint V Seat
    RPM 2" 4 point harness
    Bond Roll Bars Full bolt in Cage
    *Exterior
    yellow
    Lipped and rolled gaurds
    a bit off rust in usual spots
    * Wheels
    2 hoshinos 14 x 7.5 -2 With Toyo R888 185/60/14 Fronts
    2 Hoshinos 14 x 8 -4 With Toyo R888 185/60/14 Rears
    2 MA's with 185/60/14 Yoko C-Drive (spares)
    Last edited by stouty; 18th November 2009 at 03:50 PM. Reason: Update on builds list of parts
    Leigh
    Forster
    Have a bond half bolt in roll cage waiting to go in just need to get the plates welded on to the legs.
    Grip TE72
    http://www.ae86drivingclub.com.au/fo...read.php?t=276
    AJPS for all you Toyota goodies
    Veteran blair's Avatar
    Blair
    Sheldon
    anything new man??
    got any shots of how the wheels sit?
    looks nice
  • #4
    Veteran slydar's Avatar
    Dimitri
    should not look at this thing.. giving me ideas..
  • #5
    Blair
    Sheldon
    giving ME ideas! hahaha
  • #6
    Veteran shift_rook's Avatar
    SE Burbs
    slydar make a wicked t-18, can't wait till mine's done, there'll be some inspiration for ya. exact same colouor too.
    this thing is pimp. like it a lot
  • #7
    Leigh
    Forster
    Cage is getting fitted now.
    Run my first hillclimb at King Edward Park just north of newcastle. Finished 2nd in my class (2u) out of 9 with a 37.23 so im pretty happy, just got to get a LSD locker sucks arse too much understeer coming into corners.
    Going to do AE86 coilover conversion up front and when Apex Engineering is back up get the rear coilovers going to go with 7kg up front and 5kg in rear should be a nice combo for the hillclimbs and maybe a drift day here and there at raleigh international raceway.
    Grip TE72
  • #8
    Nat
    Newcastle
    Hey mate - you would have been running at Ringwood Park, King Edward is in October (awesome event, right in Newcastle, but try and become part of the state champs if you want to enter as you will do well to get in)
    Second last corner is worst for understeer, I have a locker in mine with 8kg/6kg springs and didn't have issues on any other corner
    Your t18 looks hot as by the way!
  • #9
    Senior Member shuvke70's Avatar
    Jarryd
    Para Hills
    something different! yeww!
    have u done the 86 steer rack conversion yet? (sorry if u posted that up or not)
  • #10
    性交を愛する marvis's Avatar
    I like. Looks hot.
    Quote Originally Posted by trikzlane View Post
    I love streeting, Lowdown cars and watching the world unwind by every word Marv types.
    Quote Originally Posted by keiichi View Post
    dont you get raped by the police everywhere you go?
  • Page 1 of 9 1 2 3 4 5 6 7 8 9 LastLast
    1. 14x8 hoshinos (perth)
      By coFF33 in forum Car Parts For Sale - Wheels
      Last Post: 18th August 2012, 01:03 AM
    2. Te72
      By R&D Mechanical in forum KE70 / AE71 Owners Forums
      Last Post: 5th November 2011, 09:45 AM
    3. Replies: 16
      Last Post: 6th August 2010, 07:35 PM
    4. te72 non rolling shell cheap adl
      By bigdaddykane in forum Cars for Sale (Toyota Only)
      Last Post: 10th May 2010, 09:12 PM
    5. [VIC] 15' Hoshinos - Awesome Fitment
      By chaRwie in forum Car Parts For Sale
      Last Post: 1st May 2010, 07:38 PM
