club4ag, technical, jdm redtop/smallport/ae92/whatever they call it=> ecu pin number, wire coulour + function. You can figure out the rest from there.
yellow green is dash water temp gauge
yellow black is dash oil pressure sender/switch. smallport cars have oil lights or oil pressure gauge? Need to match the sender to car.
The browns are just earths.
wtf are you doing? did you get a loom cut off at the firewall and trying to piece it together back to the stock ecu plugs that you got from somewhere else?
