Results 1 to 10 of 13
Thread: painting bumbers
    Joe
    Bellbowrie
    Default painting bumbers
    hey guys, hope this is the rite section for this, please move if not, im thinking about painting the bumpers on my trueno flat black instead of gloss black, i want them to look factory as i have just purchased a oem front lip spoiler for it so i was hopping to get the new colour as close to the oem look as possible, so i was hopeing that some one could steer me in the rite direction on what paint to use and how to prep the bumper for paint? thank you in advanced for the help guys
    cheers; joe
    stay classy
    dan
    adelaide
    adelaide
    use satin would look better
    there are a few oew bumper paints available look pretty good factory satin finish
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    i was going to make a tech article on this today but didnt because the pictures i took for it didnt turn out very well.
    1. buy some matte/flat black paint. you will need probably 250ml of acrylic and mix50/50 thinners or 2 cans for each bumper (i buy the cheap fiddly bits from bunnings because its the most cost effective).
    2. prime and sand back so the bumper is smooth.
    3. spray the bumper using normal spray technique. apply 2-3 coats. it will look smoot flat black.
    4. mist coat. apply whilst the last coat of flat black is still wet. holding your gun/can 2x the normal distance (about 40cm) away from the surface cover the bumper with a quick sweeping motion. do this to the whole bumper 3-4 times.
    this will cause the paint particles to slightly dry whilst in the air. this will cause them not to run together giving a grainy effect, which looks like the oem plastic's rouch surface
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Mine were painted before I got mine (So I'm not 100% sure what the oem finish is like but I have a good idea). But I ran down to my local parts store grabbed a few cans of primer filler and some bumper paint (Flat black).
    Sprayed about 2-4 coats of primer filler, rubbed it all back to get a good smoothe finish. Hit it with some 400 grit to rough it up.
    Then about 2-3 decents coats of bumper paint, the stuff I bought has a different texture, it seems to go on alot thicker and doesn't run. Mine came out pretty well. But I was going for a smoothe flat black finish, whereas you will probably want the ripple effect.
    Joe
    Bellbowrie
    riojin: thanks mate thats a great help, and thank you for the tip to get the grainy effect thats just what im after
    dish: thank you mate will pop down to repco or the likes and get some paint and primer, any pacific brands that i should use? ive used k and h for something else and it seemed pretty decent, so yea may use that or if any one can recomend something better im all ears, thanks for the replys guys!!
    cheers joe
    stay classy
    Oldschool Member
    Mar 2005
    Roy
    Bris
    K&H is the only shit I like, everything I've painted I try and use K&H. Works best for me. Only problem is the bumper paint wasn't K&H I had to buy some other brand. But still went well. I think it was Septone bumper paint.
    Veteran dori_86's Avatar
    Jaidan
    Adelaide Hills
    yeah used septone paint, only use the bumper bar prime,its black anyway and gives a nice coat, but i wouldnt suggest using the paint from experience as it isnt as flexible and cracks, i did a write up on the old forums when i painted my front bar with lip, dont have to do anything special just prep the bumper as per the instructions on the can (i think.. light rubbed down and wax/grease remover) then spray light coats
    Jaidan
    Adelaide Hills
    heres some of the pics from it
    性交を愛する
    Win!
    marvis.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    Quote Originally Posted by riojin View Post
    IF YOU USE THIS PAINT YOU WILL DIE!!!!!!!
    seriously though, dont EVER buy that paint if you want a quality finish. it is $3.17 for a reason. i would rather not paint it at all than to use fiddly bits. the only thing its good for is doing stencils. and even then its still terrabad paint.
    if you like to shop at bunnings id like to recomend actually white knight for the most cost effective. even though i dont like the quality of that paint, it is definatly 1 hundred billion times better than fiddly bits...
    fiddly bits is the crap that people buy to inhale the fumes. definatly not for the cost effectivness of painting something.
    FTP.
  1. Replies: 0
    Last Post: 15th July 2010, 02:18 PM
  2. WTB T18 chrome front / rear bumbers for ke70
    By leo_palmer in forum Cars or Parts Wanted
    Last Post: 14th June 2010, 02:15 PM
  3. VIC AE86 bumbers
    By otanica in forum Car Parts For Sale
    Last Post: 18th January 2010, 01:16 PM
  4. t-18 chrome bumbers F/S
    By rthy in forum Car Parts For Sale
    Last Post: 16th December 2007, 10:05 PM
  5. Panda Painting
    By kurtis in forum General Topics (No Technical Questions)
    Last Post: 29th January 2007, 06:48 AM
