Results 1 to 3 of 3
Thread: need help to check for short circuit
    Eddy
    Default need help to check for short circuit
    My ST162 3sge has a short which i couldn't find where the problem is. It doesnt burn the fuse, it's just draining the battery slowly.
    Anybody here who's good in automotive wiring that can give me a hand? or if u guys can recommend a shop that'll not burn a hole in my pocket that'll be great. Thanks.
    Veteran slide86's Avatar
    Huw
    Hills
    you need a multimeter that can read amps.....
    to do a current draw test
    1) remove the negative terminal
    2) add the multimeter in SERIES with the neg terminal and negative battery post
    3) set the multimeter to AMPS and monitor what the reading is
    4) after 5 mins there should be no more than 0.07amps
    if it is anymore, go through the fuse box and pull one fuse out at a time, when you see the amps drop to almost zero, the circuit you jst pulled out will be the one that is draining the battery. ie
    - 2 amps indicated on multimeter
    - remove radio fuse
    - amps drops to 0.03 amps
    therefore the radio circuit is drawing the current
    Aaron
    ^^^ fucken bang right there
    but if it was a newer car i would leave it for more than five minutes
  • Similar Threads
    1. Anyone here able to help with Printed Circuit Boards?
      By Nicko in forum Technical - Questions
      Last Post: 20th May 2011, 04:39 PM
    2. ebisu circuit
      By sun_moon in forum Other International Events and Discussion
      Last Post: 10th July 2010, 04:07 PM
    3. My circuit sprint Sprinter
      By HighLife in forum AE86 Owners Forums
      Last Post: 8th July 2008, 04:57 PM
    4. ke70 circuit
      By Gavin in forum Toyotas in the Media
      Last Post: 5th October 2007, 10:25 AM
