Results 1 to 4 of 4
Thread: Hilux brake upgrade part #
    Reeece
    Casula
    Default Hilux brake upgrade part #
    Hey guys , i bought my hachi awhile ago with front hilux 4 spot brakes ... it consist of peugot rotors.. I am just needing to know what model brake pads i need for these calipers and how do find out what model peugot the rotor came from ?? Anyone that has done this conversion or knows what needs to be done could you please help me.. cheers
    Reece
    Jonathan
    Most likely the brakes are from a LN106 or similar 4WD HiLux. Most 4WD HiLuxs from the 90's will have the same front pads. So very easy to find the pads.
    The peugot rotors are slightly modifyed from standard. (Machined down from about 270mm to about 254mm I think). They are ment to be 20mm thick. You had best measure them and look up the dimentions in disk brake catalogs. Not hard to find the right ones.
    Senior Member sr_rolla's Avatar
    beau
    Bathurst
    peugeot 604 rotors, they may not be machined either, the caliper can b filed a touch to clear instead. As above on the pads tho.
  • #4
    Reeece
    Casula
    thanks heaps guys
  • Similar Threads
    1. VIC: AE71 Panelvan Drift car part out! w55, hilux, 4age ect.
      By Sprinter86 in forum Car Parts For Sale
      Last Post: 13th February 2013, 10:05 AM
    2. Hilux 4 Pot brake upgrade.
      By Faceplant456 in forum Technical - Questions
      Last Post: 2nd March 2010, 12:43 AM
    3. Replies: 5
      Last Post: 12th July 2009, 08:44 PM
    4. hilux xt130 brake upgrade
      Last Post: 6th June 2008, 10:17 PM
    5. WTB: hilux diff upgrade
      By deanoo in forum Cars or Parts Wanted
      Last Post: 30th October 2007, 02:10 PM
