Page 1 of 11 1 2 3 4 5 6 7 8 9 10 ... LastLast
Results 1 to 10 of 103
Thread: Rack Tech
    Gone
    Joel
    Picton
    Default Rack Tech
    so talking to some of the boys here and seems to be that their is some unknown mistery about our manual racks.
    heres some info ive been able to gather by having an Ae86 GTV rack and Standard Rack side by side
    different types: Manual racks
    Factory
    1. GTV
    2. Standard
    Part #'s
    1. ER2 - 40
    2. ER1 - 10
    Turns Lock to Lock:
    1. 3.6 / with AJPS Lock spacer - 3.9!! will massive angle
    2. 3.3
    Distance from case end to Rack end (see pic below)
    1. 156mm
    2. 144mm
    Aftermarket:
    Quafie
    *the part number is on the drivers side mount.
    *Turns lock to lock were measured with the racks on the floor, marking a point and counting turns of main input shaft
    * the noticable difference was once both rack were at full lock the amount of travel was visuably noticable as u can see above (case -Rack end distance mm)
    pics to explain below
    fee free to add to it
    Andrew
    Quote Originally Posted by sundee86 View Post
    Turns Lock to Lock:
    2. 3.3
    So the sportier rack is slower than a normal one? Is that right?
    Veteran Robo86's Avatar
    Rob
    hmmm cool.
    its weird i have a 87' GT rack and its different to a standard rack (aus etc) because the ajps lock spacer fouls on something
    http://shirtstuckedin.com/
    my corolla
    Bosman Wholesale Tyres
    3274 5374 - Roy
    Gone
    Joel
    Picton
    Quote Originally Posted by Robo86 View Post
    hmmm cool.
    The AJPS lock spacer fouls a little on mine to. it fouls on the internal bush on the pax side but i think it should be right after a little driving.
    as for the racks some guys say that the GTV has a better ratio. i dont know about that, it has more turns lock to lock and more travel than a standard aus spec rack.
    with my 14's up front , the GTV rack and the lock spacer i can't achieve full lock because the wheel hits the rear inner of the wheel arch, i think its actually hitting the break line bracket
    性交を愛する
    I really need to put my spacer in.
    Good post.
    marvis.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Moved to Tech Articles
    Gone
    Joel
    Picton
    thanks Golberg, Oh yek yeah RAck spacer FTW!!! the Lock angle is intence!
    ill get a pic up on tuesday once i get wheel alignment ,
    but specs are:
    GTV Rack.. 12mm more travel than adm (as above)
    PS arms
    AJPS Lock spacer
    its gonna be rediculous... its gonna be a forklift, i just need to put a knob on the steering wheel hehehe
    i think the lock spacers were missmachined...
    i got dave to send me a second one thinkin the first one was just accident/oldstock or something.. but both were the same...
    2 minutes with a file worked it out.
    Gone
    Joel
    Picton
    yeah its not much ATM when the lock spacer goes through the end bush it just gets a bit tighter, but not much
    yeh i tried both on a 2 seperate rackes.. and then again wen i changed housings... and it was knocking on the seal... quite annoying really.
  1. XT130's with P/S rack, longer rack ends?
    By Jimmee1990 in forum Technical - Questions
    Last Post: 6th December 2011, 07:31 PM
  2. Know your tech rules
    By sundee in forum Technical - Articles
    Last Post: 9th August 2011, 02:32 PM
  3. [melb] rack ends and rack bushes
    By shakes in forum Car Parts For Sale
    Last Post: 10th May 2010, 09:28 PM
  4. Replies: 1
    Last Post: 3rd November 2009, 07:52 PM
  5. rack end and rack bush for ae86 power steering rack
    By quoccy in forum Cars or Parts Wanted
    Last Post: 28th June 2008, 12:58 PM
