Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: how to remove spigot bearing?
  1. #11
    Josh
    Gunningbland
    I just find a socket that matches the bearing OD and bash it out the side that doesn't have the retaining lip with a hammer :/
    This is assuming the flywheel's not attached to the engine of course...
  2. #12
    Oldschool Member
    Mar 2005
    Roy
    Bris
    Fly on or not, it's kind of hard to bash a bearing through the crank shaft till it pops out. Might be there for a while.
  3. #13
    Josh
    Gunningbland
    Ah, so a 4A spigot's in the crank? Like a Magna? Fair enough
    Carry on
  4. #14
    Tan
    West
    newpaper + grease did it for me.
  5. #15
    john
    nsw
    liverpool
    pilot bearing puller also works... take like 2mins ..
  6. #16
    Jun 2013
    Ella
    Ballarat
    Use a thread cutting tap, i can't remember what size, but use one with an extra 2 or 3 mm on the inside diameter of the spigot bush, wind it in and it will bottom out on the back of the crank, keep turning and it will eject the bush. I tried the grease trick but tap will surely work.
  1. spigot bearing
    By blake. in forum Technical - Questions
    Last Post: 1st August 2010, 04:02 PM
  2. Spigot Bearing
    By 86 Nick in forum Technical - Questions
    Last Post: 4th June 2008, 08:51 PM
  3. Spigot bearing
    By QUINN in forum Technical - Questions
    Last Post: 3rd December 2007, 12:00 AM
  4. Spigot Bearing
    By Monk in forum Technical - Questions
    Last Post: 23rd December 2006, 01:33 PM
  5. spigot bearing
    By drif86s in forum Technical - Questions
    Last Post: 7th September 2006, 06:49 PM
