pm sent
complete 3sge rwd conversion (think its a gen 2 ) has all parts to fit engine
3sge with 2s sump
rebuilt borg warner box (approx 300km)
modified water system with volvo radiator
tail shaft to suit borg warner diff
modified factory extractors and full exhaust
modified cross member
NO INLET NO ECU WAS RUNNING WEBBERS HAS CAMRY DIZZY
$1200
front coilovers xt130 struts with control arms less than 300kms on them
koni yellow inserts
6kg springs with helpers
s13 adjustable tops
peguot disc
hilux 4 piston calipers
braided brake lines
$1100
trd t series lsd centre with 4.3 ratio
$450
t series drum brake diff open centre complete no brakes
$300
borg warner diff converted to disc no handbrake cables
$300
xt130 struts and control arms have ke70/ae86 springs and spring perch monroe inserts
$250
4x 14" wheels suit ke70 new tyres (maybe 100km on them)
$400
pair of 14x6.5 mesh bbs wheels avrage tyres
$100
pair 16x7 roh wheels tyres no good
$100
will post more photos when i get in the garage
Warren 0414 867 992
pm sent
ROYAL GARAGE NEWCASTLE
pm's replied
do you still have the 4.3 LSD. is it for big or small axles??
still have it it suits small axle
I would have a 2s bellhousing with slave, fork and release bearing for this set-up for sale, allows you to fit a W5* gearbox
ADM AE86 Levin
pm me with info & price on the lsd please
hey mate,
is it a pinion carrier with pinion?
or is it just the centre with the 4:3 crown?
its the centre with crown wheel and pinion
engine pakage SOLD
