5 sets in stock, ready to ship.
Product - Techno Toy NRCA's
Model Specific - Ae86
Info:
35mm tall
Red Anodized 6061 T6 aluminum
Light weight design
Solid Milled alignment sleeves
Large Solid Milled center alignment ring Providing even more sheer protection
Engineered and designed to insure the absolute best durability and strength possible.
All hardware is Metric Grade 10.9 and 12.9 alloy steel, that is equivalent to SAE Grade 8 and higher.
Tech:
These Negative Camber RCA's will provide 2.8 degrees of camber on a car dropped 2". On a car dropped 3" they will provide 3.1 degrees of negative camber
(these figures are IN ADDITION to the camber your car already has, so if you already have 1.2 degrees of camber at 2" drop, then you would have 4 degrees overall of negative camber)
These units will also widen the front track of the car by 25mm per side (50mm overall increase in front track). Used with Camber plates, they will allow you to run moderate camber with a much wider track or absolutely insane amounts of camber 5+ degrees.
What you get:
2 x 35mm NRCA's
4 x new Grade 10.9 Hex bolts
4 x new Grade 12.9 Allan Bolts
4 x HT spring washers
Fitting instructions
Price:
$USD140 + US$40 int ship/pair
Related Products
price update
