Results 1 to 8 of 8
Thread: Rear side windows- removal
    Mick
    Penrith
    Default Rear side windows- removal
    I've gotta take out the fixed side window on the passenger side of my sprinter to fix some rust. I was wondering, what is the best way to do it? last time i tried taking a fixed window out i smashed it, so i dont want to make that mistake again...
    Veteran Nikkojoe's Avatar
    Tom
    If its not been removed before (factory sponge sealer), its pretty easy. Undo all the retaining clips (remove the screws and they will come off). Once thats done, see how stuck down the window is (it may come off fairly easy). If not, get a stanley knife and begin to cut the foam sealer while gently pulling on the window toward you (i would start from the top of the hatch area first and work down to the bottom). You can also remove the trim inside the car and cut the sealer inside (just be careful and make sure the window wont drop ). Once the sealer is cut, it should come off.
    To replace the foam, bunnings sell single sided glued foam rolls for sealing doors and joints. Its a little thicker than you need so cut the strip down the middle, peal back the tape and stick it to how the old one was applied on your window. On the non sticky side, apply some rubber/contact cement/adhesive and fix the window back to the car.
    Senior Member superbmobile's Avatar
    Justin
    Happy Valley
    I personally wouldn't bother with the original style foam, just use the sikaflex brand window sealer its about $20 a tube from bunnings and stores a like, all you need is a corking gun.
  • #4
    Veteran dr1ft-pig's Avatar
    Brendan
    NORTHSIDE YO
    to get them out i used a ziptie... make a hole in the sikaflex and stick the ziptie through, ten just drag it around the seal while pulling gently on the window
    smae method as windscreen fitters use but obviously they dont use zipties
    MY JZX83 (clicky)
  • #5
    Tom
    Sikaflex is for lazy people, but it will give you more work to do if it comes out again! The ziptie method worked on the foam, but not on the sikaflex when i did it (it really was some hard shit) :/ Took me 2 days to remove all the old sikaflex!
  • #6
    Justin
    Happy Valley
    ^ Yeah true, one of my side windows had been redone with sikaflex at some stage and it was truly a royal cunt to get out.
  • #7
    i did my rear with piano string/ guitar string. poke a hole get someone inside, and CAREFULLY run it around. once's it's off get a good solvent/ paint cleaner, prep sol. to clean away the nasty stuff.. any paint supply place( perhaps the same store that will supply your prep sol,) will have window sealant in a coiled up strip, it's much easier to apply, than the tube's with require a special high powered caulking gun. ask them for a suggestion tell them what your doing. asking never costs anything so it's worth asking people who deal with this type of work everyday.
  • #8
    Dwayne
    Toowoomba
    what about the clips holding the window in? does anybody know where to get replacements (part numbers or similar parts from another vehicle)?
    a fair few of mine broke or were already broken the first time i took my windows out, so my window trim doesn't clip on properly anymore. it even flaps a bit in the wind on the highway.
  • Similar Threads
    1. wtb ke70 wagon rear side windows
      By chalk in forum Cars or Parts Wanted
      Last Post: 13th August 2012, 11:02 PM
    2. windows,winders,side mirrors, trims
      By BLIPAE86 in forum Car Parts For Sale
      Last Post: 28th July 2011, 09:16 PM
    3. Ke30 panel van no side windows
      By SEXY 16 in forum Cars for Sale (Toyota Only)
      Last Post: 29th July 2009, 02:25 PM
    4. WTB: Trim for ae86 fixed side windows
      By Vizz in forum Cars or Parts Wanted
      Last Post: 5th January 2009, 07:38 PM
    5. [NSW] F/S w/pics windows, rear bar, rear lights, interior
      By Buddy in forum Car Parts For Sale
      Last Post: 3rd May 2007, 07:52 AM
