Results 1 to 10 of 12
Thread: Eddies Street sex machine
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    Default Eddies Street sex machine
    So I bought this baby my 3rd 86 back about 2006 for $800 as a shell with complete panels and half a dash a welded s series.
    It was light yellow with a black bonnet. bought a bigport 4ag for 100 bucks and all the accesories to make it run and got a t series for freeeeee.
    I stripped it down to a rolling shell and trailered it to work, repaired all the rust, got rid of the door locks and resprayed it in dark purple with blue and red pearl. Got a jblood copy front and vertex rear bar and some struts with a magna rotor and galant caliper convo and of course ps arms, also already had ta23 celica lcas. put the full interior in and drove it to work for a while as is.
    Then i had a little spare cash and decided it was time to make it fast about 2 years ago. I had a spare ze from my skid car, a smallport head and all the other pieces off the na engine. had a spare clutch and the old t series from my drift car with TRD 2 way.
    Had a t28 nonbb turbs lying around aswell so that went on and tuned it on 12ps1 for 129kw wich farkin flew.
    THe old t28 was blowing massive ammounts smoke so I decided it was time to make it look a bit better in the engine bay so i re-wired the fuse box and moved it under the dash to clean that up. While this was in progress i blew up my skid 4a engine and put the SR in, so i had the flyhweel clutch and w56 hilux gearbox out of a 2004 lux and the t28bb. Back on the dyno and tuned on 13psi made 135kw and with the lux ratios was an absolute weapon on the street.
    With all the mods the car was getting a bit too much to drive on the street and rudely enough Japanese motorsport had a silvertop 20v which i couldnt refuse. So i decided it was time to build a decent na engine as i have never had a powerful NA engine, well that and getting my 2 first speeding fines in the bastard in a year!!!!
    so now its sitting in the shed waititng for someone to buy the turbs engine so i can get the 20v in there!!!! build pics up later
    MODS
    Body
    Full respray in purple
    no door locks
    j-blood copy frt bar
    vertex rear bar
    Interior
    stock
    Suspension and Handling
    FRT
    stock shocks
    stock cut springs
    magna vented rotors
    galant calipers
    s13 brake lines
    ps arms
    biggest swaybar from whiteline
    REAR
    3.9kg cut rear springs
    biggest whiteline swaybar
    stock shocks
    Engine and driveline
    ST162 radiator
    DEKKA dry cell battery
    Polished rocker covers
    bigport low comp 4agze (late model)
    TRD 0.8mm H/G
    smallport head with T3 adaptor
    JDM RWD mani
    JDM RWD Alternator + water piping
    Microtech lt10 ecu running dizzy setup
    TRD spark prug leads
    JUst Jap cooler
    bosch coil
    vs commo airbox with pipe work to suit
    T28bb jappy s15 turbo, adjustable wastegate
    w55gbox out of 2004 model hilux
    215mm extreeme flywheel and clutch 900kg clamping
    shortened t series tailshaft
    exhaust with 2 lukey boxes 2.5 in to stainles tip
    T series with TRD 2 way
Name:	PA160027 (Small) edited.JPG
ID:	1813   Click image for larger version.
Name:	PA160029 (Small).JPG
ID:	1814   Click image for larger version.
Name:	PA160030 (Small) edited.JPG
ID:	1815   Click image for larger version.
Name:	4a engine.jpg
    AE86 THE BEST
    man that looks mint ay grate work love it
    Member trb20v's Avatar
    Jason
    Port Macquarie
    very cool, paint looks good and nice clean engine bay too...
    Veteran shift_rook's Avatar
    SE Burbs
    i understand why you call it the sex machine. very nice man, love it
    Eddie
    sa
    well after a long time there may be something happeneing with this soon, i took it off the road because i got 2 speeding finres in 2 months back in 2009. had plans of putting a na 20v in but lost inrerest so its just been sitting in the shed under a cover.
    Im swapping the wbox and bits so i can run a t50 behind the 20v i have all the 20v bits to get it going all i need is an airbox and an ecu as ill put the micro thats currently in it atm into my other 4ag sprinter cos the haltech has fked out. my gf is hammering me to get it going again, quick build at lewis engines and on the dyno will be sweet!!!
    AE86 THE BEST
    Glenn ke_70's Avatar
    Clay
    Barossa!
    ive wanted to see this for awhile now
    i thought you sold the turbs motor?
    Eddie
    sa
    yer parted it all out another lad has it in his race car, has been a while since its been going.!!!
    AE86 THE BEST
    Paul
    Maidstone
    Hot wet sex
    2 in the pink 1 in the stink
    Senior Member Danzo's Avatar
    Danzo
    Cheltenham
    Haha if you didn't buy this thing off me it would probably still be on axle stands in my driveway . Nice work
    DTF - Danzo Technical Factory
    Eddie
    sa
    not doing much better its on axle stands in my shed lol!! i should post pic up of what it looked like when i got it has come a long way!!!
    AE86 THE BEST
  1. Honda City SEX MACHINE (Adelaide SA)
    By LukeKE11 in forum Cars for Sale (Not Toyotas)
    Last Post: 13th February 2012, 11:35 PM
  2. Fast eddies first 4x4
    By FAST EDDIE in forum Other Rides
    Last Post: 19th June 2010, 04:15 PM
  3. Fast eddies ke70 shiiiiiik
    By FAST EDDIE in forum KE70 / AE71 Owners Forums
    Last Post: 14th May 2009, 11:51 PM
  4. FAST EDDIES NEW SHOW
    By orangechargd86 in forum AE86 Owners Forums
    Last Post: 8th May 2007, 02:35 PM
  5. Eddies new 86's no 4 and 5
    Last Post: 12th March 2007, 08:58 PM
