Results 1 to 3 of 3
Thread: Injector Service Kit - need some help!
    Nat
    Newcastle
    Default Injector Service Kit - need some help!
    Good evening all
    I am currently installing efi onto the bigport 4age in my ae71. I am also replacing all the injector seals, etc so that I don't have any nasty fuel leaks when it is all back together.
    My question is, in the top of the injector (on the end that plugs into the fuel rail) there is a microfilter - basically a thin mesh cylinder that pushes down into the top of the injector - does anyone know how the hell to get it out? I have new filters in the kits I purchased so would definitely like to change them over (especially as I think I have damaged one trying to get it out). I can't find any clips or anything like that, so I am assuming it basically pulls out of the injector and the new one slides back in.
    If anyone could shed some light it would be greatly appreciated
    Cheers, Nat
    was it much cheaper to do it urself.. i thought it was like 25$ including parts to have it done + flowed.
    Nat
    Newcastle
    The kit cost $30 - other than this little filter I can't get out it will probably take me about 1 min per injector to do. I'd say it would be $25 per injector to have it done professionally
    Can anyone help me with this stupid filter? Or should I just cut it and pull it out that way?
  • Similar Threads
    1. Service Checklist?
      By haydenz in forum Technical - Questions
      Last Post: 14th January 2010, 01:46 PM
    2. who do you use to bid on yahoo? i need a new service
      By slide86 in forum General Topics (No Technical Questions)
      Last Post: 18th November 2009, 01:55 PM
    3. how often do you service your 86?
      By Mattysshop in forum General Topics (No Technical Questions)
      Last Post: 18th September 2008, 09:47 PM
