take the barrel from ya passenger side door, they have a special tool that takes a print of the key that it's meant to be and they carve you out a new key, take the passenger side door as it's less worn than drivers door
hey guys..
my key snapped in the key hole as i was trying to unlock my hatch. unfortunately i dont have a spare. is there any kind of lock smith that can help me make a new one?
unlucky. pretty sure if you take the lock out and take it to a "key grinder place" they can get a blank key and make a new one.
thanks alot champ. is there like a specific place u gonna take it too or just to any key cutting shop?
if its an adm spoony jus ask someone local to get a copy of their key all adm's are the same.
lol i dont think that they would want me to have a key that could access my car as well as theirs.
i snapped a key in my ex's car door, luck be it that i was able to open it.
took the barrel out, got the other half of the key out. then just take the the 2 halves to a lock smith to make a new one.
Pfffttt..... I use my house key to open and start my spoontah.
maybe you should just get a paddle pop stick and use that for a key?
but yeah like most people said locksmiths can make you a new key if you take the barrel too them
get the ones that come to you...
get them to cut one from the 2 halfs.. and then then can keep test fitting on the lock.. each time they try the barell will leave fresh marks so they no where to cut.
