Results 1 to 8 of 8
Thread: ae86 front windscreen
    Veteran ae86's Avatar
    Dave
    Western Suburbs
    Default ae86 front windscreen
    wondering if anyone knows what windscreens are able to be used ?
    COROLLA SPRINTER (AE86) 84-86 TY025 GB 740 U 0
    COROLLA SPRINTER SEDAN (AE85) 85-87 TY019 GB 740 U 0
    im unsure if ae85 will fit ? anyone able to clarify if its exactly same bodyshape ? and this corrola spritner only classify's 84-86 year model ? mines an 83. dave.
    Veteran Nikkojoe's Avatar
    Tom
    83-85 (ae86 or ae85) will fit, im not sure if later model will fit early and visa versa (i know that the window moulding on zenki and kouki are different - can't remember if its due to a physical window size difference).
    Veteran johl's Avatar
    Johl
    also am unsure but there is definately 2 different size windows. not sure if it was coupe to hatch or zenki to kouki but one window is alot longer as it doesnt have that panel around the windscreen wipers
    Dave
    Western Suburbs
    uncool =( ae85 matched up with ae82 windwows i think which is a bit fishy
    Tom
    Yeah thats definately not right, if your windscreen quote/part number is based off an australian supplier, it will mostlike be for the early model and should fit your car (ie the ae86 part no. you listed is probably correct). Its definately a zenki/kouki, not coupe and hatch.
    Senior Member RolandGTV85's Avatar
    Roland
    Bassendean
    The AE85 window and all Jap 86 windows compared to the Australian windows are longer. In other words, from Top to bottom, The Australian window is shorter. Can cause fitting problems (but can be done) and yes all Zenki and kouki Trim is different to Aussie. I've been down this path before. Has nothing to do with early or newer models. the Jap windows are just different. Prob something to do with road standards.
    Veteran Wally's Avatar
    yeah found this out when Keven had a crow go through his window.
    Shame the windows aren't the same for an easy replacement.
    Also not sure if all jap cars, but I know Keven's coupe the glass didn't have the file to hold it all together.
    4AGE 16V
    Dave
    Western Suburbs
    well those part numbers were based in NZ
  1. WTB AE86 ADM Rear right side tail light & Front windscreen upper trim
    By Turbulence in forum Cars or Parts Wanted
    Last Post: 15th July 2010, 06:23 PM
  2. ae86 relay for front windscreen wiper!
    By sic86 in forum Technical - Questions
    Last Post: 11th April 2010, 12:40 PM
  3. SA; AE86 ADM Front Upper Windscreen Trim
    By swan86 in forum Cars or Parts Wanted
    Last Post: 23rd November 2009, 06:16 PM
  4. nsw : ae86 front windscreen, tinted door glass
    By evil86 in forum Car Parts For Sale
    Last Post: 11th January 2009, 09:25 PM
  5. AE86 Bottom Front Windscreen Mould
    By drft_86 in forum Cars or Parts Wanted
    Last Post: 10th August 2008, 12:38 PM
