Results 1 to 5 of 5
Thread: main relays?
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    Default main relays?
    hey guys,
    found out my main relay has gone swimming, so i need to get a new one.
    its for a bigport rwd 4age loom. are they the same as the ae82 16v ones? its a 5 pin inline relay with a yellow base and a black cover. anyone got one for sale?
    thanks for your help.
    Clinton
    FTP.
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    You're not talking about a circuit opening relay are you?
    Where is it located? Part no?
    Clinton
    Tweed Heads
    its located near the ecu, its got a part number on it but 24 years has rubbed off abit of the writing on it. forgot to mention its for a rwd 4age harness.
    it says ciruit open on the top of it then the old 'TEJ' style toyota logo and a part numbe that looks like '9*910-***0' or something along the lines of that
    FTP.
  • #4
    Lawrence
    Wollongong
    Does it have a 6 pin plug, except only 5 pins are actually there?
  • #5
    Jonathan
    The AE82 one will be the same, if it looks the same. Same with most EFI Toyotas of that era.
  • Similar Threads
    1. 20v main bearings
      By hau oi in forum Technical - Questions
      Last Post: 2nd January 2011, 03:31 PM
    2. trueno pop up lights including relays and motors + REAR BAR
      By julzy in forum Cars or Parts Wanted
      Last Post: 29th March 2010, 05:40 PM
    3. rear main seal
      By sic86 in forum Cars or Parts Wanted
      Last Post: 13th October 2009, 01:17 AM
    4. Light relays
      By corknose in forum Technical - Questions
      Last Post: 10th April 2009, 07:49 PM
    5. Main Fusible Link
      By tunney in forum Technical - Questions
      Last Post: 1st April 2006, 08:05 PM
