Page 1 of 138 1 2 3 4 5 6 7 8 9 10 11 51 101 ... LastLast
Results 1 to 10 of 1375
Thread: pen15's slider could be lower wider louder
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    Default pen15's slider could be lower wider louder
    now this
    was this
    the specs are as follows
    suspension
    -up front GReddy coilovers
    -up the back GReddy coilovers
    -whiteline front strut brace
    -whiteline 24mm adjustable swaybar
    -cusco pillowball caster rods
    -rear adjustable panhard rod whiteline
    -19mm rear adjustable swaybar whiteline
    -t3 scratch built adjustable lower control arms
    -40mm rca's AJPS articles
    -t3 steering arms
    -t3 pillowball turnbuckle outer tierods
    engine
    -blackbox m1
    -7age 16v bigport
    -t3 bigport to ae101 quad throttle adapter
    -spool con rods
    -wiseco pistons comp is 12.37-1
    -ae101 silvertop quad throttles
    -t3 raw stacks
    -264 hks cam shafts at 8.1mm lift on intake and 8.35mm lift on exhaust
    -cast headers with custom secondary's
    -o2 sensor
    -highflow metal cat converter
    -2 1/2 inch straight through
    -dirty exit pipe
    -jap spec sprinter radiator
    -Bosch 044 intank pump
    oils
    -engine oil is royal purple 10w40
    -gearbox oil is royal purple 90w140 and a mix of 75w90 and a nulon oil stabilizer
    -diff oil royal purple maxgear 75w90
    drive train
    -tight t50 gearbox jdm
    -short shifter kit very nice kit Q's i think
    -sprinter tailshaft front section rear half is t18
    -t series koukie 1.5way TRD
    -4.77's techno pro spirit diff ratios
    -copper jap shifter rebuild kit
    -jdm brakes up front slotted and vented rotors
    -project mu pads up front
    -disc rear end with project mu drift rear pads
    -braided lines from front to back
    -stewert wilkins hydro handbrake
    -braided lines to above
    -willwood brake bias adjuster (in car)
    wheels
    - 14 by 8 -12 mk2's up front
    - 14 by 8.5 -10 mk2's at the rear
    tires
    - 185 60 r14 getting re001's up the front
    - 185 60 r14 triangles up the rear (good tires don't dlam at all)
    interior
    -bride zeta3 lowmax on bride rails to suit ae70
    -fake bride deicent copy passenger
    -nardi classic
    -d1 quick reliese steering wheel hub
    -autometer nexus gauges (oil press, water temp)
    -defi tacho
    -velo racing harness 4 point
    -jvc tv dvd headunit
    -gutted interior
ID:	95   Click image for larger version.
ID:	96   Click image for larger version.
ID:	97   Click image for larger version.
ID:	98   Click image for larger version.
    Dave
    The Ghetto
    clean, tidy build
    Davey & Riki-lee
    South Australia
    Seaford SA
    yeeah nice build dude!
    any new plans with the car?
    Davey & Riki-lee
    South Australia
    Seaford SA
    also any motor pics?!
    Mathew
    Sutho Shire
    Quote Originally Posted by Dave View Post
    clean, tidy build
    cheers m8 appreciate it
    the dyno pull to 300rwkw
    Mathew
    Sutho Shire
    Quote Originally Posted by AE70 View Post
    got a bottom end i can get built up but considering my options cams in mind atm went for a slide last night and wasn't happy with the power in the dry need a set of them other than that getting my handling all set up wright
    also engine pic coming up it looks sorta stupid with earthing wires everywhere but its really responsive with it in
    also included is a pic of my gauges and dash setup
ID:	264   Click image for larger version.
    Brandon
    Blackwater
    thats so fresh. looks mint as. is a nice build ay
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    mat you do know that earthing kit seriously wont do anything
    also with the money you paid to get that manifold made up you could of got itb's... did you realise that?
    FTP.
    Nat
    Newcastle
    Looks hot - what's the specs on those wheels?
    Mathew
    Sutho Shire
    wheels are 13 by 8.5 minilights
    update on engine pics with newly added airbox from my daily workhorse vr commie doing a post on how to D.I.Y all required is a couple of brackets and a block off plate and presto all done it looks fairly stock too runs smother with it in also btw this is the reason i didn't go itbs Clint cheers boys good to see some other people know a nice looking rolla when they see 1
ID:	333   Click image for larger version.
  1. Sprinter00086's slider.. Now lower, wider and sexier :)
    By Sprinter00086 in forum AE86 Owners Forums
    Last Post: 9th December 2011, 05:21 PM
  2. pen15's stuff for sale
    By pen15 in forum Car Parts For Sale
    Last Post: 20th April 2011, 07:36 AM
  3. drift vids by pen15
    By pen15 in forum The Drift Channel
    Last Post: 18th May 2010, 08:25 AM
  4. pen15's tow slut!
    By pen15 in forum Other Rides
    Last Post: 18th April 2010, 08:58 PM
  5. pen15's ride
    By pen15 in forum KE70 / AE71 Owners Forums
    Last Post: 3rd October 2008, 06:33 PM
