Results 1 to 10 of 11
Thread: timing a 4age with quads and 256 cam
    gawler area.
    Default timing a 4age with quads and 256 cam
    hey all
    im trying too time my 4age
    its got quads and a 256 int cam
    iv got it set on 10degs when running but its lumpy and sounds like it not running right
    just seeing if any one can help me out
    dehney
    Peter
    Kellyville
    try 15 degrees. Typically need some more advance with the bigger cams. Assuming the cam is degreed in OK and you have decent map sense for the quads
    gawler area.
    yeah ill give that ok cheers man
    A
    Parky
    What ecu are you running?
    gawler area.
    Quote Originally Posted by julzy View Post
    iv got a chipped 4ag ecu from japan it come with the motor that i got the head from
    Gone
    Joel
    Picton
    One thing u have to be careful of it that the japs run 100 ron fuel and we only get 98 so u wont be able to give it as much timing. I have the same 256 cams portrd big port and quads I tried 15' advance ( diag port bridged) which is 20' advance unbridged and it didn't like it, ATM I've got it set at 12' advance but I've also got cam gears that have been dialed in but I don't know what their set at. I'm running stock big port jdm ecu and S-afc . Idle is lumpy but a 16v with cams will have a lumpy idle.
    gawler area.
    i see iv got it going oh about 15 i think but still got the bad idle like its idling like a v8
    do i have to tune my quads in ?
    if so does any one know how to do that
    cheers dehney
    Peter
    Kellyville
    Default tuning
    I take it you have a vac line set up (4 lines in to a pot of some sort) to try to get a good signal to the map sensor?
    What cam timing did you set up?
    gawler area.
    Quote Originally Posted by hinricp View Post
    yeah iv got all four going into one for the map sensor
    what do u mean by cam timing iv got it set on both makes on the steel plate behind the cam gears
    Peter
    Kellyville
    Default Cam timing
    Rather than repeat it - check this link
    http://www.billzilla.org/4agmods2.htm
    You note 4 lines joined together but is there a vessel to smoothe the pulses?
  1. Replies: 7
    Last Post: 4th August 2011, 10:23 PM
  2. HKS 256 cam, Foglights, RWD plenum, TRD leads
    By 70XIN in forum Car Parts For Sale
    Last Post: 17th November 2010, 01:59 AM
  3. 4age clear timing cover , adjustable cam gears and cams
    By tubby in forum Cars or Parts Wanted
    Last Post: 13th July 2010, 02:46 PM
  4. small port and big port heads, 256 cam,16v rwd water stuff
    By dehney in forum Car Parts For Sale
    Last Post: 17th December 2009, 05:24 PM
  5. WTB-4AGE cam covers/timing cover
    By Dori86 in forum Cars or Parts Wanted
    Last Post: 21st April 2007, 05:14 PM
