Results 1 to 7 of 7
Thread: Rebuilding racks
    Veteran starni_boy's Avatar
    Clint
    Sutherland Shire
    Default Rebuilding racks
    Hey.
    Just after some advice on rebuilding my steering rack.
    Going to buy all new seals etc, got a quaife rack etc to go in. Just wondering how people go about disassembling them. What sort of tools etc they use?
    Don't plan on rebuilding it, will pay to get that done. All I want to do is disassemble and machine a few things.
    I did search, but didnt find.
    http://files.aeu86.org/manuals/AE86Manual.pdf
    itll be in there.
    i found a massive socket at work that fits instead of the sst. it was like 2inches or sumthing 40mm? cant remember. but yeh.. 22mm spanner i think.. shifter.. pick pluss that big 12point socket.
    if you read of the manual and start doing it will notice its prettty straight forward.. except for the bottom bearing. heatfitted.
    Rian
    Mt Macedon
    I found it easy to pull apart and put back together. Though I used vice grips for the big lock rings and a big bolt head for the massive hex sockets.
    It isn't a complicated bit of equipment.
    Clint
    Sutherland Shire
    Cheers. Remembered I had a service manual underneath a pile of paper, so just used that.
    Took about 10 minutes to disassemble!
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Its the power steering rack which is way more fun
    Veteran shift_rook's Avatar
    SE Burbs
    i've had trouble findi9ng the seals and stuff to rebuild mine... will just have to look in different places. quaife rack ftw
    Jonathan
    What seals are you talking about? The manual rack has almost none.
  1. Rebuilding LCA's
    By shawn_26 in forum Technical - Questions
    Last Post: 1st December 2009, 06:09 PM
  2. Rebuilding shocks
    By benzo in forum Adelaide & SA Events and Discussion
    Last Post: 16th October 2009, 11:34 AM
  3. rebuilding motor?
    By 86TRD in forum Offtopic Discussions
    Last Post: 5th August 2009, 12:45 AM
  4. Rebuilding shockers
    By stylz in forum Technical - Questions
    Last Post: 13th August 2008, 12:04 AM
  5. Need Rebuilding??
    By SIC86 in forum Technical - Questions
    Last Post: 21st July 2005, 08:57 PM
