Results 1 to 7 of 7
Thread: 20 Valve Blacktop to RWD?
    Jacks
    nsw
    sydney
    Default 20 Valve Blacktop to RWD?
    Does anyone know any good Mechanics in Sydney to do this conversion from FWD to RWD, and roughly the cost? I heard there was a bolt on part that bolts on the the engine that will convert it without needed mechanics to modify parts around.. T5 or something? Does anyone know anything about this?
    Jonathan
    I will be making a few 20v rwd kits in a few weeks. A few other guys on here can make the parts also. I don't think there is a commercially available kit in Australia.
    Steve
    Quote Originally Posted by mr.smirfy View Post
    Perhaps your t5 theory could be Techno Toy Tuning aka T3.
    when you do a conversion you will rarely get/find a straight swap kit. Something new/changed always has to happen.
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    wait for jonny rochester's kit. check it out in his build thread. easily the simplest one.
    FTP.
    Jacks
    nsw
    sydney
    Quote Originally Posted by Jonny Rochester View Post
    I wouldn't have a clue on how to convert it myself anyway.. I need someone who knows what they are doing to help me with it, dont want to end up fucking my whole motor up when I try to attempt to do it myself lol..
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Quote Originally Posted by Clinton View Post
    while I like the look of Jonny's conversion I disagree with this comment. To do it that way from what I take it you have to do the following to a bare head:
    - strip all parts off head,
    - take head off block
    - drill/machine channel/hole between ports at the back
    - drill and tap a blind threaded hole in the back of the head
    - source an 4age 16V rear outlet
    - modify rear outlet holes to be a little further apart
    - bolt up rear outlet
    - bolt up block off plate using one of the original holes and the newly threaded hole
    I think thats it, Jonny tell me if I am wrong here and no disrespect intended.
    otherwise you can just put a plate on with a machined external bypass and do it up, total tools needed one: a 12mm spanner. I admit it doesnt look as factory and I dont think what I do because I sell a bolt up part. I have known about this method for about a year now. Just my personal preference.
    Something else, have you finished your top water pipes yet Jonny? I want to in the future send my customers to you as I dont want to make them anymore.
    Sutherland
    I can do the conversion for you and am in Sydney, Check my bt in my built thread and PM me if interested.
    Cheers, ben
  1. 20 valve Blacktop ECU Grounding Points
    By hayashi in forum Technical - Questions
    Last Post: 20th August 2012, 08:39 PM
  2. Blacktop 20 valve head bolts possible replacements?
    By sdrawkcab in forum Technical - Questions
    Last Post: 14th August 2011, 01:29 AM
  3. AE71 Blacktop 20 valve project QLD
    By stixy in forum Cars for Sale (Toyota Only)
    Last Post: 23rd March 2011, 06:57 PM
  4. 20 valve blacktop conversion
    By ap7 in forum Cars or Parts Wanted
    Last Post: 12th July 2008, 10:57 PM
  5. dli systems for 20 valve blacktop
    By darkness86 in forum Cars or Parts Wanted
    Last Post: 3rd June 2007, 11:55 AM
