thinking about getting one off my mate soon
whats the pros and con?...
do i need it or just something extra for nothing? lol
dose
WTF is an air flow controller?
a throttle,
elaborate,,,
thats the one
mates got one in his 180sx, piggy back ecu type...not apexi but an afc
not to sure how they work or benifit...at work with stupid server blocking nearly everything i try to view at work so cant do much research on them
so anyone used them and seen the positives or negs?...i so far think its a good mod to have
dose
My understandings of the AFC is that it allows you to manipulate the signal coming from your airflow meter to allow you to richen or lean out your tune. I guess if you have an afm car and don't want to fork out on a programmable ecu it can be a good thing. A friend with an NA RB25 had his cylinder head shaved to bump up comp and used an AFC which worked fairly well.
i suggest a air flow gauge .. so you can monitor if your car is leaning out or runnign rich .... im sure ive seen them around .
they work good especially on turbo motors i got an safc on my sr20 and it works well
what engine do you have?
on my fields afc unit it has a lean/rich light running the whole time, instead of a gauge
i think that they are good if you understand that they are no substitute for a fully aftermarket ecu
