I've been using my red SA63 Auto as a daily from Yatala to the Gold Coast and back for the past 6 months or so. I've now got a new car so I don't need it anymore.
Details
Red, Auto. Rego till May. Has a couple of spots of rust just below the back drivers side window, and another right down the bottom directly below. Had rust in the hatch but I've swapped another hatch onto it which has no rust at all. Gearbox was reco'd when I bought it 6 months ago as it had been run out of oil. New fuel pump fitted 6 months ago. Fitted with Aircon but I'd say it needs regassing. One of the pwr steering hoses leaks when you're on full lock. The engine runs well albeit uses a bit of oil, not smokey however. Drivers door handle is a bit dodgey and key doesn't match the locks.
If you're interested I'm at Yatala. I suggest you come around and take a look.
$1000. get a mate to drop you off and drive it home
Trav.
