Results 1 to 4 of 4
Thread: 3T-C not firing on one cyl
    Thumbs down 3T-C not firing on one cyl
    okay so ill start from the start, yesterday my battery was completely flat (to the point where i could not even push start it) a friend jump started the car no worries, i was only minutes from home so once i arrived i decided to leave the car to idol for a bit so i could start the car the following day. I fell asleep and the car ran out of petrol duing the night
    once i got petrol in it and got it running again today it was not firing on one cyl, i cant think of any reason why this would suddenly happen just because i left it idoling for a while (probably only about an hour as there was very very little fuel left)
    I have tried simple things like re-seating the plugs at both ends, is there anything else i should try?
    thanks in advance for the help!
    Jonathan
    Look at your points. Maybe they burnt a bit when the iginition was left on?
    Hugh
    Maybe, seeing all the shit, dirty fuel in your tank went through the fuel system, you may have a bif of dirt clogged in one of your injectors...isolate the cylinder that isn't firing and go from there...
    性交を愛する
    I always thought you needed to be driving for the battery to charge?
  1. new cams on 4ge but not firing
    By dehney in forum Technical - Questions
    Last Post: 27th March 2011, 12:06 PM
  2. firing problem
    By callum1 in forum Technical - Questions
    Last Post: 7th May 2009, 12:31 PM
  3. speedo cable, brake mater cyl, clutch master cyl
    By dr1ft-pig in forum Car Parts For Sale
    Last Post: 9th June 2008, 12:24 PM
  4. firing order for a 4ag
    By TRD_86 in forum General Topics (No Technical Questions)
    Last Post: 20th February 2008, 08:19 PM
  5. 4age firing on two cylinders
    By fozz in forum Technical - Questions
    Last Post: 26th March 2006, 11:12 AM
