Results 1 to 10 of 13
Thread: Easy way to figure out differential gear ratio?
    Veteran Wally's Avatar
    Default Easy way to figure out differential gear ratio?
    Hi guys,
    I'm not entirely certain what differential gear ratio I am running in my JDM 86 has a TRD 2way in it, though not sure what diff gear ratio thats in there.
    Does anyone know a way to work it out?
    On the highway it touches 4000rpm at 117km/h which is pretty high, I don't remember my ADM being like that.
    Any help would be great
    Cheers,
    Chris.
    4AGE 16V
    Akio
    Mt Haruna
    Japan
    its a 4.3 wally. at about 3500-3700rpm, should be about 100km/h, and 4300-4500rpm should be about 120km/h.
    the kid had a similar thing as well, was unsure what his ratio was.
    Thanks mate.
    Yer 4000rpm and its dead smack on 117 (digital dash).
    Hoping the new TRD tranny gear set doesn't much around with it too much in top gear.
    4AGE 16V
    Veteran slydar's Avatar
    Dimitri
    4000x60 = rev/h 240000
    240000/.861 (t50 5th gear ratio) =278745.6
    278745.6 = revs at diff' drive flange per hour
    roll out on 185 60 14 = 1.8146m
    1000m/1.8146 = 551.1 revs per klm.
    so 64478.7 revs per 117k
    278745.6/64478.7= x
    = 4.3xxx
    its nice to brush up on some infrequently used maths skills every now and them
    Senior Member Adsie's Avatar
    Adam
    Birkdale
    Wouldn't your speedo be out once you change your diff ratio?
    Jonathan
    That is right. But the tacho is still true. So you can calculate your real speed knowing your revs, gearbox ratio, diff ratio, and tyre circumferance.
    Veteran driftke70's Avatar
    Ryan
    Buderim
    dodge way is to mark your tail shaft and tyre, turn your tail shaft one full rev and see how many the outside of your tyre does.
    wheelfriends.wordpress.com
    Akio
    Mt Haruna
    Japan
    Quote Originally Posted by Wally View Post
    Thanks mate.
    from what i know, the TRD 3 set and TRD 5 set dont really change the final drive ratio in the gear box.
    i know for sure that the TRD 3 set doesnt touch the final gear.
    Yer i think the 5th gear in TRD set is virtually if not the same.
    mmm so would that mean it's displaying slower or faster?
    278745.6/64478.7= x
    = 4.3xxx
    oh awesome.
    go a spreadsheet?
    4AGE 16V
    Dimitri
    i can do simple maths, but not spread sheets
    anyway, your cars jdm? and the box is too? your speedo will be correct then, j' cars come with a 4.3.
  1. Differential Gear Ratio
    By mikare in forum Technical - Questions
    Last Post: 16th September 2014, 08:49 PM
  2. w57 close ratio gear box
    By Celica RA45 in forum Car Parts For Sale
    Last Post: 28th August 2011, 10:09 PM
  3. Gear Ratio (Final) Selection?
    By assassin10000 in forum Technical - Questions
    Last Post: 15th August 2011, 10:24 PM
  4. Differential Gear Ratio
    Last Post: 23rd September 2010, 10:22 AM
  5. gear ratio and speed -w50
    By redsprinter in forum Technical - Questions
    Last Post: 8th September 2009, 01:13 PM
