its a 4.3 wally. at about 3500-3700rpm, should be about 100km/h, and 4300-4500rpm should be about 120km/h.
the kid had a similar thing as well, was unsure what his ratio was.
Hi guys,
I'm not entirely certain what differential gear ratio I am running in my JDM 86 has a TRD 2way in it, though not sure what diff gear ratio thats in there.
Does anyone know a way to work it out?
On the highway it touches 4000rpm at 117km/h which is pretty high, I don't remember my ADM being like that.
Any help would be great
Cheers,
Chris.
4AGE 16V
Thanks mate.
Yer 4000rpm and its dead smack on 117 (digital dash).
Hoping the new TRD tranny gear set doesn't much around with it too much in top gear.
4AGE 16V
4000x60 = rev/h 240000
240000/.861 (t50 5th gear ratio) =278745.6
278745.6 = revs at diff' drive flange per hour
roll out on 185 60 14 = 1.8146m
1000m/1.8146 = 551.1 revs per klm.
so 64478.7 revs per 117k
278745.6/64478.7= x
= 4.3xxx
its nice to brush up on some infrequently used maths skills every now and them
Wouldn't your speedo be out once you change your diff ratio?
That is right. But the tacho is still true. So you can calculate your real speed knowing your revs, gearbox ratio, diff ratio, and tyre circumferance.
dodge way is to mark your tail shaft and tyre, turn your tail shaft one full rev and see how many the outside of your tyre does.
wheelfriends.wordpress.com
from what i know, the TRD 3 set and TRD 5 set dont really change the final drive ratio in the gear box.
i know for sure that the TRD 3 set doesnt touch the final gear.
Yer i think the 5th gear in TRD set is virtually if not the same.
mmm so would that mean it's displaying slower or faster?
oh awesome.
go a spreadsheet?
4AGE 16V
i can do simple maths, but not spread sheets
anyway, your cars jdm? and the box is too? your speedo will be correct then, j' cars come with a 4.3.
