Well i sold some corolla shit i had lying around to fund other shit:
360mm Nardi classic
K&N filter
CSX Grillzz
New leads, plugs, rocker gasket, rear main, rear g/box seal.
New rack ends, tie rod ends, ball joints
Superpro LCA, sway bar, castor rod bushes.
Extweem H/D crutch + pressure plate
Southern Ways Mesh, 15x8 -6, 15x8.5 -6
Pair 195/55 RE001's
RA60 struts + vented brakes + P/S arms, becoming 9kg coilovers next week
Cusco S13 Cambertops
Cusco S13 strut brace
Headunit and 6x9's
Think thats it so far, cut the springz bra so it looks a bit like this:
KYB AGX, Custom RCA's and spot welding coming then to start on the rear which will have:
RT142 Disc brake diff with 4.11 ratio
7kg AJPS spring
Boge S/S rear shock
AJPS panhard rod
93A Superpro trailing arm bushes
30mm Lowered shock mounts
Spot welded reinforced Panhard rod mount, 4 link mounts, swaybar mounts
Custom boot brace
