Results 1 to 10 of 10
Thread: Radiator mounting - show me
    Dan
    Vic
    Western Subs
    Question Radiator mounting - show me
    Hi guys,
    just wanted to see how you guys have done your brackets to mound your radiators. my stock 4k one seems to be clogged and i have 2 sapre rads sitting here - one is from an ae82 4age and the other i think is a 4ac new can people just post pics of where and how they have mounted them so i have an idea tomorrow when i do it
    thanks guys!
    . h i t o r i k o .
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    mine is held onto the rad support with tie wire...
    they should sit on the og bottom mounts pretty well?
    ae71 4ac rad and 4k rad will be the same unless one is from an auto and one it from a manual.
    just go to a wreckers and get the top radiator mounts off the cars, if you dont know which cars they are from. tiewire.
    FTP.
    Calvin
    Kilsyth
    4ac and 4k rads are totally different. if you have a ke and u use an ae71 radiator it'll need custom mount brackets.
    hito: it all depends on what mount setup the radiator had in the car it came from. just see what it was and copy that into the ke. doesn't have to be super perfect just needs to work.
    T18 in the build
    Clinton
    Tweed Heads
    Quote Originally Posted by Hokey View Post
    really? as in AE71 4ac radiator are completly different or AE86 4ac ones are completly different?
    when we pulled radiators out of AE71s at the wrecker for the KE70s they were exact size except the auto ones where a bit thicker.
    i know that AE86 radiator is different to a AE71 but they are both 4ac
    FTP.
    Calvin
    Kilsyth
    when i put a ae71 4ac radiator in my ke70 i had to use custom mounts as the ae radiator is wider. ae71's have a different width gap in the front panel for a radiator with different mounts to the kesev
    T18 in the build
    Site Supporter Javal's Avatar
    Josho
    And Spoonter radiators are different again.
    Dave
    exactly what i found.
    i currently have a ae71 radiator in my ke (so the inlet/outlets are on the right side for the 4age)
    i ended up putting one bolt in on one side, and then using tie wire on the other side. so it sits a little of centre but doesnt move.
    i dont think pics are goin to help ya mate as its just a matter of "making it fit".
    just take out the ke radiator, chuck the other one in.. and see if any bolt holes line up, and if they dont just drill a few new holes and chuck some bolts in!
    try giving your current radiator a decent flush, holding hand over bottom outlet, filling it up, and letting it all gush out...do this multimple times untill you notice a difference, you might find your current one is ok.
    Scammer, DO NOT BUY FROM ME!
    i have an ae71 one in my ke held in by zip ties, a couple of the holes line up though
    Dan
    Vic
    Western Subs
    fixed it - sorta
    since my car is an auto it was the oil cooler at teh bottom that was blocking it and yeah manual 4k radiator and 4age oilcooler later its fixed...sorta
    . h i t o r i k o .
    Calvin
    Kilsyth
    haha just make a bracket. you only need an angle grinder and a drill. it'll be much better than cable ties or tie wire haha
    T18 in the build
  1. Replies: 3
    Last Post: 11th June 2012, 08:22 PM
  2. Replies: 2
    Last Post: 9th March 2011, 03:41 AM
  3. Radiator/Intercooler mounting and Shroud
    By bigm in forum Technical - Questions
    Last Post: 14th November 2009, 03:54 PM
  4. CA mounting
    By squish_m8 in forum Technical - Questions
    Last Post: 4th April 2009, 12:03 AM
