Results 1 to 7 of 7
Thread: Stroke Ratios. 4age vs 7age
    New Zealand doesn't have States
    Epsom
    New Zealand
    Default Stroke Ratios. 4age vs 7age
    Just doing a bit more study. I know people bad mouth wiki all the time but I cant help that its such a user friendly source.
    http://en.wikipedia.org/wiki/4AGE#4A-G_.2816-valve.29
    The link goes on to say the of the A series engines the 4age is the most race bred being over square bore/stroke. And the 7afe loses this to it economy style set up keeping the 81mm bore seen in the 4 series but increasing the stroke from 77mm to 85.5mm making it very much under square.
    It doesnt say this but by my mind a heavily under square bore/stroke ratio means that the piston has to travel further than its over square 4age counterpart? Im not sure if im right or not. This would mean the what the 4a lacks in displacement make up for in top end power due to a high rpm favoured set up leading to it screaming passed the 7 series with ITBs wide open .
    I know the 7age set up is mainly for torque but in doing that is the top end scarficed?
    Anyone out there who has driven a decent 4age and or a decent 7 series please share your thoughts.
    Cheers,
    -Jamehij
    add ITB's and decent cams to a 7a and ull hav no problems in the top end with the added torque lower down
    also remeber on wikipedia they are refering to the 7afe as a stock pos...not the "improved" 7age version
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I agree with delazy, if you look at the bore/stroke ratios of the ZZ engines you will see they are way under square and yet they still have a highish rev limit and max power made at a high rpm.
    Epsom
    New Zealand
    Cool so you can tinker with the power curve quite alot by selcting approprite cams? What kinda rpm can they see safely? Modded of course. That of the 4age?
    Yea the extra torque looks very appealing.
    Veteran shift_rook's Avatar
    SE Burbs
    it just depends how much you wanna spend, i'm sure it could rev out very closely to a
    4age. i've decided to go 7age as i've found a 4age head and 7a blocks are piss to find at the wreckers, give it a rebuild with some goodies and it should be sweet
    Endeavour Hills
    yeah cams and intake tuning can shift the power curve around, as for your second question see here:
    http://www.ae86drivingclub.com.au/fo...ead.php?t=1308
    Epsom
    New Zealand
  1. Replies: 22
    Last Post: 5th March 2012, 10:33 AM
  2. 4age bigport, 7afe, 7age, smallport or 20v
    By z250junker in forum Cars or Parts Wanted
    Last Post: 6th November 2011, 10:41 PM
  3. 4AGE/7AGE early rev-limiter and no power
    By Robo86 in forum Technical - Questions
    Last Post: 15th February 2010, 08:06 PM
  4. getting over this 7age/4age shit
    By toyoda in forum Car Parts For Sale
    Last Post: 14th July 2009, 09:19 AM
  5. 4AGE to 7AGE
    By stouty in forum General Topics (No Technical Questions)
    Last Post: 14th September 2006, 09:29 PM
