Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: wheel alignment
    Senior Member 70wagon's Avatar
    Jarrad
    Barossa
    Default wheel alignment
    hey all
    got a wheel alignment done last night
    thought id take some of the settings ive seen on here in. i decided to go with
    caster-stock rods maxed out: +3
    toe: 1mm out over all
    camber-non adjustable(rona arms): -1.3
    thats with 8kg adjustable coilovers
    and it wasnt bad, so i first thought till i slid the first corner, the first half of the corner was great then it just wanted to straighten up strait away
    im guessing if i run a little less castor this will solve the problem??
    what would be the best set up in my case for drift?
    any help would be exellent!
    thank you
    jarrad
    Jonathan
    Wait untill it rains next time, or go harder.
    Jarrad
    Barossa
    lol sure
    are those settings ok?
    Jonathan
    1mm toe-out is up to opinion. I would go zero toe.
    Jarrad
    Barossa
    dose 1mm out make it real twitchy?
    Veteran johl's Avatar
    Johl
    i run similar setup to that (-2.5 camber, 1mm toe out, +2 degrees castor) and dont have any of those problems. what is the rest of your suspension setup like? swaybars etc?
    Veteran FAST EDDIE's Avatar
    Eddie
    sa
    probably cos youre running 35kw lol, what do you meen by stratening up? understeering or not continuing a slide, if its the 2nd option get some smaller tires like 155 50 14s if its the first option lAck of camber will do it espacialy cos you have re001s on front(unless youre running 40psi in them lol!
    AE86 THE BEST
    Jarrad
    Barossa
    real funny eddie. wer not all rich pannel beaters like you lol.
    well i checked my tyre pressures.. they wer all over the shop its not as bad so im getting another wheel alignment tuesday and going to bring my castor back to 2.. they think that should fix it.
    thanks all
    Your car straightens up after a slide? doesnt sound like a problem with a wheel alignment problem to me.. think about it
    Jarrad
    Barossa
    lol thats what it sounds like but its not how i ment it....it wants to straiten up as soon as ive started haha but i had wack pressures in my tyres 48 in one front n 34 in the other front so that has pretty much fixed the problem lol
  1. wheel alignment setups
    By ae86 in forum Technical - Articles
    Last Post: 13th August 2011, 01:52 AM
  2. wheel alignment
    By pogi in forum Technical - Questions
    Last Post: 20th September 2009, 02:19 AM
  3. Wheel Alignment Place
    By tauhu86 in forum Perth & WA Events and Discussion
    Last Post: 17th July 2009, 04:58 PM
  4. Wheel Alignment Settings?
    By riojin in forum Technical - Questions
    Last Post: 7th February 2008, 10:12 AM
