Results 1 to 6 of 6
Thread: alternator question
    c
    Default alternator question
    What should a alternator output be on a 3tc?
    My car went flat the other day (left my lights on) so iv charged it and now the volt meter in the car is now only reading about 13v whilst driving and drops below 12v if i have my lights on and indicator on.
    Volt meter was on about 14v before the battery went flat
    Would my alt be on the way out?
    Any other ideas?
    Senior Member all torque's Avatar
    Could be a slightly lose belt.
    Quote Originally Posted by slydar View Post
    The real question is - if you can not even make an attempt to write a question in the manner in which someone is likely going to want to answer it... do you really think you're capable of doing an engine conversion?
    c
    Quote Originally Posted by all torque View Post
    Nope iv made sure of that
    Dodgy connection/loose wire? Voltage regulator, perhaps?
    c
    yeah i was thinking the reg
    Mason
    Salisbury East
    Hey mate
    Get hold of a multimeter and check voltage at alternator Pos+ terminal
    and then at the Battery + terminal.
    Voltage at the alternator should be 13.8 > 14.5 volts,
    Max voltage difference between them shouldn't be more than .2 to .5 volts.
  1. Alternator question
    By bennyq in forum Technical - Questions
    Last Post: 11th November 2011, 07:18 PM
  2. Yet another Alternator wiring question...
    By Andy San in forum Technical - Questions
    Last Post: 5th October 2011, 08:40 PM
  3. Alternator Question...
    By Shahzan in forum Technical - Questions
    Last Post: 2nd November 2009, 04:46 PM
  4. Quick clutch question and spigot question
    By wideslider in forum Technical - Questions
    Last Post: 9th August 2008, 12:45 AM
  5. 4ac - 4age 16v bigport conversion alternator question
    By Leigh in forum Technical - Questions
    Last Post: 19th May 2008, 03:04 PM
