Results 1 to 7 of 7
Thread: Fuel rail Q.
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Default Fuel rail Q.
    What is the odd bulby thing on the feed side on a bigport fuel rail.???
    And do I need it.??
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    fuel pressure regulator? lol nah man just chuck it out
    FTP.
    Veteran slydar's Avatar
    Dimitri
    lol. you give wicked sarcastic advise clinton. its funny cos youre never even on the right track yourself lol.
    he said feed...
    anyway, the answer is its a "pulsation dampener".
    its function is quite self explanatory.
    andrew
    and you dont need it.
    Dave
    Quote Originally Posted by fixeruperer View Post
    but it is there for a reason.....
    id leave it in if you have it....
    also what were you thinking of replacing it with? as i didnt have one on a fuel rail i had, so went down to the local fitting shop and had a very hard timing matching up all the threads. needed like 2 adaptors to make it work. worked out quite expensive. then i found a complete fuel rail for cheap and used that instead....
    Jason
    Nundah
    I originally went to buy a banjo fitting for it and that was a pain in the arse and the guy at the store just asked me what it does.. I have absolutly no idea and apart from fuel flowing throw it I couldn't see any usefull purpose for it so I just got an M12x1.5 to -4 adaptor and then a -4 90* bend.
    If the engine will run fine without then it can stay off. cause I honestly couldn't be stuffed trying to find then right fitting for it...
    Cheers guys
    Mt Macedon
    My thoughts too. I kept it until it became a pain to keep. Since ditching it I haven't noticed any issues.
  1. bigport fuel rail
    By Sprinter Freak in forum Cars or Parts Wanted
    Last Post: 16th April 2012, 08:45 PM
  2. Smallport fuel rail
    By Nikkojoe in forum Perth & WA Events and Discussion
    Last Post: 14th March 2012, 11:40 PM
  3. Replies: 5
    Last Post: 4th November 2011, 12:59 PM
  4. fuel rail adaptor plate for aftermarket fuel pressure reg
    By 1sik20valve in forum Cars or Parts Wanted
    Last Post: 5th January 2010, 02:18 PM
  5. fuel rail
    By drftr86 in forum Cars or Parts Wanted
    Last Post: 6th November 2007, 04:36 PM
