Results 1 to 3 of 3
Thread: Quick steering wheel question
    Senior Member all torque's Avatar
    Default Quick steering wheel question
    Can anyone confirm whether or not Nardi and Momo use the same spacing pattern, i.e. will a Nardi wheel fit on a Momo boss?
    Quote Originally Posted by slydar View Post
    The real question is - if you can not even make an attempt to write a question in the manner in which someone is likely going to want to answer it... do you really think you're capable of doing an engine conversion?
    Jonathan
    There are only 2 hole patterns in common use, and most boss kits now have both holes drilled and tapped in them. So any steering wheel should fit, unless your unlucky.
    Thanks Jonny.
  • Similar Threads
    1. Quick release steering wheel hub
      By panda trueno in forum Car Parts For Sale
      Last Post: 17th July 2009, 09:27 AM
    2. Quick Release Steering Wheel Hub
      By ke25 racer in forum Car Parts For Sale
      Last Post: 8th May 2007, 09:23 PM
