Results 1 to 5 of 5
Thread: engine runs rich and won't rev
    Senior Member --Redwork--'s Avatar
    Jason
    Nundah
    Default engine runs rich and won't rev
    Just finished my conversion today.
    Wired it to JAP spec as it has JDM ecu and car started first try but won't rev and poors out fuel smoke.
    This is my first convertion so I'm not 100% sure I have all the sensors needed to run the engine properly....
    Definatly missing a Knock sensor.
    Theres also HEAPS of extra plugs that looks a right mess.
    What could cause it to run so bad.?
    On te plus side it sounds tuff as..
    Nathan
    Lilydale
    first thing i would do is ask the ecu.
    if the ecu is the cause, (ie. 'limp' mode), it will tell you why.
    you need to connect a test light across two pins in the ecu, i have forgotten which pins exactly they are, although a 2 minute googe search will no doubt tell you exactly which ones.
    thats what i would do after the usual basic checks anyway!
    Jason
    Nundah
    Ahh true... I never thought of that...
    To used to after market ecu's.
    Pitty I don't have a test light...
    First thing on the list for tomorow...!!
  • #4
    Veteran Clinton's Avatar
    Clinton
    Tweed Heads
    you could make one if you wanted to dick around.
    FTP.
  • #5
    Jason
    Nundah
    Yeah think I'll wait till tomorow and spend like 5 bucks to buy one..
    spent WAY to much time in my garage the last couple of weeks to be stuffing about making a tool that I can get down the street for next to nothing..
  • Similar Threads
    1. Replies: 24
      Last Post: 19th June 2011, 04:59 PM
    2. Engine Runs rough while under 2000rpm under load.
      By Kwan in forum Technical - Questions
      Last Post: 17th February 2011, 09:05 PM
    3. Car won't rev past 4000rpm - JDM bigport
      By Course_Out in forum Technical - Questions
      Last Post: 21st November 2009, 02:22 AM
    4. Engine won't rev over 4000rpm
      By LeviNafey in forum Technical - Questions
      Last Post: 7th August 2007, 10:16 PM
    5. WON'T REV
      By Whip in forum Technical - Questions
      Last Post: 26th May 2005, 05:49 PM
