Results 1 to 10 of 15
Thread: JDM 4age TPS part number
    Senior Member KE70's Avatar
    Alek
    Lalor
    Default JDM 4age TPS part number
    I need to order a new one but the part number thats on the TPS I have is a little smudged.
    Can someone run to their car and check the number please?
    This is for a JDM 96 KW engine.
    Can I use another TPS from another 4AGE? like a AE82 bigport with my JAP ecu?
    Senior Member adam's Avatar
    Adam
    You can use a TPS from some Cressidas and a 6cly (?) Camrys. I'll grab the part number and car models you can take them off for you tonight.
    Adam
    The part number on mine is 89452-28040.
    The cars which should also run these TPS's are,
    83-87 Corolla
    84-89 MR2
    82-85 Celica
    84-88 Cressida
    Also read that 89452-28060 should also work.
    The TPSs are easily found at the wreckers, on the search for mine at Centre Rd Wreckers, I found 4. I only stopped searching for more because they were all hard to take off (random hoses, brackets in the way of screws to remove TPS).
    Alek
    Lalor
    Thanks dude, Ill take a look at the wreckers and see what I can find.
    stefan
    vic
    eastern suburbs
    3sge celicas have the exact same tps
    Alek
    Lalor
    I managed to find one off some newish corona. Not the same part number but its the same TPS.
    My problem is not the TPS, the car still runs like crap.....
    stefan
    vic
    eastern suburbs
    whats the symptoms?
    Alek
    Lalor
    It idles just. When you throttle it, the car splutters and chokes until it reaches constant revs then it is ok, sort of. Pretty much it doesn't accelerate smoothly.
    I don't know if that explained it properly but its a bit hard to describe.
    Hugh
    mine had the same problem a while ago, and turned out it was running too rich. i worked out it was the coolant temp sensor, try unplugging it at the back of the head, and see if that makes any difference..
    Alek
    Lalor
    Quote Originally Posted by hugh View Post
    There are two sensors at the back of the head, which one do I unplug?
    Ill try after work, fingers crossed.
  1. part number for 4AGE bluetop TPS?
    By extra_anchovy in forum Technical - Questions
    Last Post: 18th October 2011, 02:35 PM
  2. part number for full jdm 86 handbrake cable
    By ae86 in forum Technical - Questions
    Last Post: 12th August 2009, 08:17 PM
  3. jdm RDA part number? diameter?
    By ae71 in forum Technical - Questions
    Last Post: 21st May 2008, 08:07 PM
  4. 20v tps part number...
    By shelldrake in forum Technical - Questions
    Last Post: 28th December 2007, 08:35 PM
  5. Part number for JDM front disks??
    By sprintrphile in forum Technical - Questions
    Last Post: 29th November 2006, 03:20 PM
