Results 1 to 4 of 4
Thread: BT & ST wiring diagram?
    Question BT & ST wiring diagram?
    hey guys just wondering if the bt and st wiring diagrams are the same? i keep searching for it but the only diagrams that come up are st. can someone steer me in the right direction? if anyone has the bt wiring diagram that can send me that would be sweet, btw this is going into a ae92.
    Anthony
    is it possible to send me the link to both if you happen to find them cheers
    Mt Macedon
    When I was looking for BT wiring diagram years ago I was told to jsut use a silvertop one. Replace the AFM with a MAP sensor and use the FC pin to control the circuit opening relay and you should be close.
    Also I can't quite remember, rallystanza may have one.
  • #4
    Moderator Sam-Q's Avatar
    Endeavour Hills
    their different, here is a silvertop diagram:
  • Similar Threads
    1. Is there a difference between bt and st 20v head???
      By slider4life in forum Technical - Questions
      Last Post: 12th July 2010, 07:50 AM
    2. Wiring diagram for AE70 & TE71
      By belstaff in forum Technical - Questions
      Last Post: 21st January 2010, 02:52 PM
    3. KE70 & AE71 wiring diagram
      By KePanelVan in forum Technical - Questions
      Last Post: 11th August 2009, 11:49 AM
    4. st/bt quads
      By slippry in forum Technical - Questions
      Last Post: 3rd July 2008, 12:10 AM
    5. Are ST and BT dizzy's interchangeable?
      By Vezza in forum Technical - Questions
      Last Post: 29th June 2007, 11:36 AM
