errr... as pointed out by --Redwork-- the following is wrong, sorry:
Depends on which way your tailshaft is spinning, I'm not sure but it might be different between cars.
If it is spinning anticlock wise looking from the rear of the car then your ring gear will need to be on the passengers side and the nose will point down as you load it up (therefore you need the nose pointing slightly up in the static/unloaded position)
If the tailshaft is spinning clockwise when looking from the rear then the ring gear is on the driver's side, the reaction of the nose will be up so the nose has to point down in the unloaded position.
Anybody knows which way the tailshaft spinns in an 80's Toyota? Or what side is the ring gear on?
Also what cars were those links in reference to?
