Results 1 to 9 of 9
Thread: Machineist? in SYD
    Ade
    SYD, Inner west
    Default Machineist? in SYD
    HI,
    Is there anyone on here or know of anyone that is a machinest on here, or in SYD?
    i have a quaife quick rack, but need some extra teeth cut into it, so i can use it with my PS arms & spacer.
    any help would be appreciated.
    http://www.ae86drivingclub.com.au/fo...es/biggrin.gif
    oh and i know i could simply look up the yellow pages....
    but i thought i might as well check and see if anyone on here does it/
    or can recommend anyone.
    ade mc
    Veteran johl's Avatar
    Johl
    its not as simple as just cutting teeth into the rack. it is flat on top just after the last teeth so they will have to build up that area and then cut more teeth into it. kinda borderline to even bothering to do it really... and the lock i get from my quick rack and p/s arms is enough to stay fast, anymore i think it would hinder you more than help you
    Ade
    SYD, Inner west
    cheers for the info,
    i knew it wouldn't be straight forward. its just that i have the rack sitting here, and i want to use it. but in order to use it along with the PS arms it needs the extra teeth.
    so if anyone could recommend a place i can get done properly, i would really appreciate it.
    also does anyone have a idea of how much it will cost? $$$$?
    ade why dont u worry about the rack later lol?
    Ade
    SYD, Inner west
    Quote Originally Posted by AE86R View Post
    well...i'm putting in rona LCA, shorter springs/shocks, PS arms...etc so i thought i might as well use it.
    well yeah true that
    Johl
    i use everything you listed. it works fine without adding teeth. would prob cost about the same as the rack did just for an extra tooth or 2. wouldnt really want any more than 3. even at that stage you will need longer tie rods
    Ade
    SYD, Inner west
    Quote Originally Posted by johl View Post
    so your runnning a quaife quick rack too?
    just that i read you need the extra teeth to utilise the quick rack.
    i can get longer tie rods, and already have longer tie rod ends.
    but if your using a quick rack with all the above monetioned parts,
    then i'll give it a go.
    Johl
    yup i also had a lock spacer when i bought it but decided to get rid of it. been to the track and there is heaps of lock with the p/s arms and quick rack. as i said before if i had any more i think my car would be too slow
  1. tailshaft SYD
    By adds in forum Cars or Parts Wanted
    Last Post: 16th June 2012, 04:13 PM
  2. SYD parts
    By bams_keto in forum Car Parts For Sale
    Last Post: 4th March 2012, 08:37 PM
  3. SYD- ke70
    By tysonke70 in forum Cars for Sale (Toyota Only)
    Last Post: 24th December 2009, 12:16 AM
  4. syd. thumpstar
    By dunga70 in forum Other Items for Sale
    Last Post: 12th August 2009, 06:47 PM
  5. syd, ma61's
    By -luke- in forum Cars or Parts Wanted
    Last Post: 10th August 2009, 03:33 PM
