Results 1 to 9 of 9
Thread: DIY Body kit moulding
    Veteran drift kid's Avatar
    Glossodia
    Default DIY Body kit moulding
    Hey, i have never made anything with fibreglass, but would like to start, im just trying to get some info on making the mould that i will eventually lay the fibreglass over, i know the basics of laying down the fibreglass, but i have no idea about making the mould, so what are some appropriate materials, steps to take, precautions etc.
    thanx.
    Senior Member 45aken's Avatar
    Marko
    talk to mfxae86,
    but from my understanding fiberglass moulds are made from fiberglass.
    you lay it over the top of what you want to mould (with releasing agent etc) then take it off and beef it up with alot more fiberglass.
    Glossodia
    ive heard that you can use anything from paper mache to bolsa wood, but i would like to clear up some things and find out what is the best way to go.
    Anthony
    i would also like to know cause i have a massive piece in the middle part of my front bar missing want to fill it in
    i know the materials needed etc just need to know how to get started ie what do i use as a mould??
    Quote Originally Posted by drift kid View Post
    Correct, I made a body kit from a chicken wire mould as long a you lay down a foundation such as glad wrap or wax to stop the fibreglass resin sticking to the mold you'll be right! so do that before you lay the fibre sheets
    Glossodia
    so what would be the best/cheapest/proffesional material to use? i have been thinking of balsa wood as its easy to shape etc, what preparations would i need to do so that i can apply the fibreglass to it?
    thnx.
    Wallan
    You usually make a "pattern" or "plug" out of something like wood, plaster, foam, etc. you just need to be able to create a solid, smooth surface on it, which you can then wax, then layup a fibreglass mould on the pattern, release, tidy up the mould, wax it, layup your part!
    Balsa would be good. MDF is also good. Make the bulk of it with ur wood of choice, then use some bog (body filler) to smooth it out, spray it with some decent primer filler, then spray it with automotive primer, get it really smooth!! If you want a really good finish, spray it with 2pac top coat, and get it super shiny with sanding, and then cut it with a buffer.
    You can skip the fibreglass mould bit, if you're confident you can make the reverse of what you want out of wood to start with.
    Remember, the better your pattern, the better your mould and hence your part. It's much easier to make bog and wood tidy than to fix up resin and glass later on!
    Moderator Sam-Q's Avatar
    Endeavour Hills
    try your local library to score a book on the subject, there's some really good books on it
    Vancouver, BC
    Downtown
    Canada
    If you're looking for a forum try www.fiberglassforums.com
  1. I'm after a body kit.
    By Dom86 in forum Cars or Parts Wanted
    Last Post: 29th May 2010, 02:10 PM
  2. DIY coilover kit using s13 struts
    By J0RD0 in forum Technical - Questions
    Last Post: 24th April 2010, 01:59 PM
  3. DIY wide body fender
    By Mr Fujiwara in forum Technical - Articles
    Last Post: 6th May 2008, 09:10 PM
  4. Everyone should have this body kit
    By crackett in forum Offtopic Discussions
    Last Post: 30th March 2007, 01:43 PM
  5. Help with body kit
    By jay019 in forum Technical - Questions
    Last Post: 27th March 2006, 12:55 AM
