Results 1 to 9 of 9
Thread: Can I use my Bigport loom on a Smallport?
    Senior Member jet111's Avatar
    Mark
    Default Can I use my Bigport loom on a Smallport?
    Ok so I dumped the idea of a 20v because I cant afford it right now. Instead I am swapping my Bigport for a Smallport, old engine is now out. I just need to find out a couple of things before I get a new one and it goes in.
    Can I use my existing loom with the Smallport? What are the differences?
    Can I use all my Bigport components on the Smallport, things like leads, starter motor, dizzy, alternator and flywheel?
    I currently have a 7rib JDM 16v. It will be replaced with a ADM 100Kw Smallport 16v.
    Thanks again.
    Nathan
    Lilydale
    all the plugs are different, and i wouldnt think that the bigport ecu would be able to run the smallport engine as well as a smallport ecu would(change in head design, higher compression etc.)
    Bottom line, dont bother. you would do much better selling your jdm engine loom, and purchase a smallport loom.
    i have a FWD smallport loom and ecu if you interested btw.
    Mark
    Quote Originally Posted by Sprinter86 View Post
    I will be running a Smallport ECU, was just hoping that it would plug into the Bigport wiring loom... If its not possible I'll be talking to you shortly. Would be nice if I didnt have to stuff around with a new loom though.
    Elite rthy's Avatar
    Leo
    Tulla
    i have a bigport loom (with bigport jdm ecu) with a smallport motor
    works good enough, tvis plug not used and pretty much all bigport acc like dizzy, injectors, etc...
    setup by toyospares...
    Nathan
    Lilydale
    well there ya go, more doable than i first thought!
    Mark
    Ok so the Bigport loom hooks up to the Smallport motor.
    But does the Smallport ECU hook up to the Bigport loom? Please say yes
    Elite rthy's Avatar
    Leo
    Tulla
    no
    the bigport ecu does quite well, altho in future i would probly change back to bigport
    Mark
    Why would you change back?
    Elite rthy's Avatar
    Leo
    Tulla
    rebuilding bigport 4age
  1. Replies: 3
    Last Post: 25th February 2011, 10:03 PM
  2. Replies: 12
    Last Post: 27th July 2010, 03:44 PM
  3. Smallport vs Bigport Loom
    By Prewer in forum Technical - Questions
    Last Post: 26th July 2009, 09:10 AM
  4. Bigport ECU into Smallport loom
    By jy086 in forum Technical - Questions
    Last Post: 24th March 2009, 10:50 PM
  5. Replies: 6
    Last Post: 22nd May 2007, 11:37 PM
