Results 1 to 7 of 7
Thread: Hot to remove Rear Bumper
    Senior Member Sprinterboy's Avatar
    Justin
    DC
    Downtown
    USA
    Default Hot to remove Rear Bumper
    Ok, for those of you that don't know hear is a little walk through on how to remove the stock rear bar off your sprinter (aus spec) I assume the Jap spec ones are much the same.
    You need to undo the bolts atop of the mudflaps and also take off the mud flaps(if fitted)
    Now thats done pull up carpet(if you still have it) and remove the four (in total) rubber plugs
    Now you will need an 19mm soket with extension to undo these as they are pretty tight, we also used a bit of leverage to help
    Now you've done that there are two more, one on either side behind the trimming
    Hear is a pic with the bolts removed
    Then....
    Ta DA!!!! Don't forget to unplug the number plate lights.
    Then fit uber new bar
    never knew this till a while back.
    Veteran Vance's Avatar
    Dan/Rio
    Randwick
    its usually best to take the tow connections out too so you dont have to struggle to remove the bar by jiggling it. the bolts for those can be accessed from under the car.
    also make sure your exhaust pipe isnt hot otherwise it may melt your rear bar when trying to remove it
    Mick
    Penrith
    Thanks man, just what i was looking for. Do you also have a guide on how to remove the wiring from the hatch, and put it back in without stuffing it up?
    Dan/Rio
    Randwick
    ^ i also would like to know that. everytime ive done it ive had to cut the wires and reattach them.
    Vancouver, BC
    Downtown
    Canada
    Quote Originally Posted by Mickey H View Post
    Slowly, carefully, and with masking tape and a pen so you can label plugs for later. You should be able to get just about everything out without cutting it up.
    Patience and a wiring diagram are invaluable tools for this job. Moreso for putting the sh*t back in though.
    Dim
    Menai
    Thank you for this guide, I removed my bumper today and miraculously there was no cancer beneath.
  1. How to remove T50 rear gearbox seal?
    By kyle unwin in forum Technical - Questions
    Last Post: 8th July 2012, 03:19 PM
  2. how do you remove a stock 86 rear bar
    By hachi_dk in forum Technical - Questions
    Last Post: 14th December 2009, 11:20 PM
  3. 180sx zenki Front bumper and rio + rear bumper $100
    By oz_eight6 in forum Car Parts For Sale
    Last Post: 12th November 2009, 08:30 AM
  4. How to remove rear hub?
    By AE86R in forum Technical - Questions
    Last Post: 14th January 2009, 12:16 PM
  5. How to remove the Stock Rear Bumper
    By rlnbye in forum Technical - Articles
    Last Post: 31st March 2008, 02:01 PM
