Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: is it possible to paint cf bonnets???
    Senior Member koulouris#03's Avatar
    Nsw
    EarlwoodNsw
    Au
    Default is it possible to paint cf bonnets???
    as stated above.
    is it possible to paint a carbon fibre bonnet????
    cheers.
    john.
    kiss ass like a bitch, so you can get ritch... but your boss gets ritcher of you!!!!
    Veteran drift kid's Avatar
    Glossodia
    absolutely, bit harder than a normal bonnet as there is a pattern that you have to paint over and it requires more prep work and more layers of paint to stop the carbon weve pattern showing through. but yes, it is possible.
    Nsw
    EarlwoodNsw
    Au
    would that add alot of weight with the paint layers???? im sure it wouldnt be much, but not sure.
    Veteran driftke70's Avatar
    Ryan
    Buderim
    just clear coat it, or paint it once, the bumpy pattern is pointless trying to cover up, and why would you want to?
    wheelfriends.wordpress.com
    Nsw
    EarlwoodNsw
    Au
    cause at least it gives the look of stockness, that cops love so much!!!!
    i dont wanna be getting pulled over everytime i go for a drive.
    what the cops dont see they dont suspect or something to that effect.
    Thomas
    West Brisbane
    it woulden't add to much weight to the panel a few kilos at most, it may depend on the finish you want, if the bonnet is in poor conditon and needs filler to fix any problems then the wieght will increase further justs depends on what your after of the finished product.
    Nsw
    EarlwoodNsw
    Au
    im chasing a light weight stock looking bonnet.
    Glossodia
    Quote Originally Posted by driftke70 View Post
    because defects arent fun.
    Veteran johl's Avatar
    Johl
    swap ur cf one for my stock one then?
    Thomas
    West Brisbane
    if ya after stock looking just get a flat sanding block with 120 grit go over whole bonnet just to get rid of the canvas look, putty it, 320grit dry rub, finish of with 800 grit wet prep and paint
  1. [BRIS] Autometer Boost Gauge with CF cup
    By capatown in forum Car Parts For Sale
    Last Post: 25th April 2012, 07:58 PM
  2. OEM Paint or Custom Paint? Whats your Flavour?
    By PeakingDuck in forum General Topics (No Technical Questions)
    Last Post: 6th December 2009, 01:15 PM
  3. bagged celsior, ucf11 CF package for sale or swapz
    By drfta7 in forum Cars for Sale (Toyota Only)
    Last Post: 16th August 2009, 07:01 PM
