Hey man. I have access to that exact SST if you want to borrow it?![]()
hey guys, planning to do a timing belt while the motor is on a stand...
Just was wondering if there was any backyard tricks to getting the harmonic balancer off?
Ive got the 4age Manuel here which shows the special service tool that your ment to use, knowing toyota if i have to buy it through them itll cost one hundred million dollars....
also how hard is it to replace the front main seal as i plan to do this while the HB is off
i have a flat piece of steal that you put 2 bolts through onto balancer and 1 were crank is and it comes of quite good.
i can bring it down for $20bucks fuel money haha
ae71 parts for sale stripping 3xae71's and a ke70
Figure (a).
Undo this bolt with a socket and long extension. Lock the motor up by getting someone to apply the brakes and have it in 5th gear.
Figure (b).
You can buy a generic puller of the same style fairly cheapish. But remember, if there are bolt threads in the pulley, they are METRIC. And probably a pitch of 1.25mm. Don't be a butcher with the wrong bolts.
Once the pully is off, clean the surfaces with emery paper. Makes it much easier the next time.
There is a generic gear puller you can buy at Bursons and Repco. Its about $30 and works a treat on harmonic balancers.
If your lucky and the balancer isn't stuck on to hard. You can wiggle them off by hand. But its highly unlikely that its not suck on tight.
use a rattle gun.![]()
^ undoing the crank bolt is the easy part
what is the #1 most abused tool in a workshop?
a flat blade screw driver. combined this with a hammer to increase power rate. and get ready for the drop. if you have a lever bar equipped you increase your chances of getting a rarer loot on the drop. 30 gold will also get you a pulling claw from master burson, and is good for other welps too like if wearing bheel decides to cast metal fusion on the stub. this can be defused with pulling claw upgrades. be wearing young vtec, you must not let the claw loose grip, or you may be in danger of destroying the harmonic balance. no go, young vtec. and bring forth victory and good news!
Clinton, I think you better go back and edit that again.
