do ferodo make pads for the ae86?
id like to try some 3000's
also, alan, as they were custom made, how much did those rotors set you back
Don't know if you wanted to see them but these are the EBC Brake Pads. I was right, they are the black ones.
I got them for stuff all becuase I work for AutObarn. I'll price them up for you today. Ferodo do make pads for them but only standard ones from memory. Ill check it out today.
Check out today - NLA are Powerblock (Cheap Shit), Bendix Metal, Bendix Steel, Ferodo Zero.
Still avaliable - Bendix Advance, Ferodo GP, Powermax (Cheap Shit) Ferodo Zero (Cheap Aswell) and EBC Black.
They may be more out there but I did it in a hurry.
Oh and they were the DB322 of heard that some use different pads.
And the Rotors
RRP Standard Kangaroo Paw - $139 each
RRP Slotted Kangaroo Paw - $159 each (not including freight) and normally take approx 4 weeks to make.
The rotors are actually the same as the ones on the AE71 Panel Van
that is rediculously cheap.
what grade are they? as in could you get them to make then in 4000 series? so the pads dont oblitherate then after one track day
did you just call up and make an order?
im in the trade too so im guessing i could probably do the same
Ferodo 3000 and the GP's/Zero's are very different.... Completly different class altogether.... i guess a good example would be Nissan N14 Pulsar and R34 GTR......
I knew that the Ferodo's are different. But there the one's that are avaliable. But im not sure if the ADM and the JDM use the same brake pads
JDM and ADM use the same pad... the JDM calipers are just a bit wider to accomodate the thicker vented disk.
Got the Project Mu Level MAX 900 fitted... Just wearing them in atm... pad feels awesome even from cold... Even not fully bedded in yet, already by far the best pads i've ever tried!! Very High coefficient of friction, but still very progressive. The pads are also very quiet, i was expecting it to squeal heaps but they dont.
I will do a review once i test them on the track.
