$150 you sure?
easy to get
150 drum to drum with hand brake cable and shaft is around the norm
wreckers are figuring out they are popular, prepare to pay up to $250 and above with tail shaft now
thats not that bad!! ill start looking now, going to ring around and try to get some round figures on engine mounts and gear box mounts
find one with a swaybar
saves some time on fucking around later on
there were sooo many more series ones (no sway) released tho
search around cant be too hard to find
i got a price for a t-series rear end, it had disc brakes and sway bars, and hand brake cable, $800
^^^That sounds like a JDM T-Series.
The T18 diffs bolt straight up to a hachi. There are plenty around, but yeh most with no sway bars. You will need a good grinder and welder to cut off your S-series ones and weld them to your T-series.
A cheap upgrade for this also is to fit a TA22 T-series diff centre. The gearset in these is a 4.1:1 ratio, which will make your engine rev up a little quicker than the 3.9:1.
AE86 4AGE "Slowly but surely"
Damn, must suck to live down south. I got my whole T-18 3.9 rear end for 85 bucks from the wrecker. Add 20 bucks for a celica 4.1 centre and $120 to get the LSD centre I had fitted to the t18 housing. Disc brakes arent really worth the premium you pay for em.
