ok cheers, thanx for the help.... kinda realised that a 40mm spacer is chunk...and the studs prob wouldnt be long enough....just needed the confirmation...
thanx again..
The wheels wouldn't fit on. They will hit the strut.
The studs aren't even close to being long enough for a 40mm spacer. So longer studs are a must. 4cm for a spacer is massive, I wouldn't recommend it.
thanx again..
to use 0 offset with 7" wide rims...and the rims sit flush.... u'll need to roll the inner guards....not too hard... but needs to be done... it depends on the tyres u use too....
and how low your car is
i wouldnt go so large diameter unless u got some huge brakes on there
